Grande Punto Cruise control aftermarket
Re: Grande Punto Cruise control aftermarket
Can someone please write the instruction what all is need to activate the CC in MES for GP 2008/10 +.
I activated 2 option in Body-can setup-adjustments and run the PROXI Alignment procedure and still not working.
I upgraded the CC with this instructions: http://www.grandepuntoclub.com/forum/vi ... 32&t=55296
Did you make the additional wire connection between stalk and body computer?
PS: Does anybody know what is the difference between body ECU numbers 51798615 and 51798616?
This is the same device.dimitar_ak wrote: 51798615 and 51798616?
yes i did, and still nothing.dimitar_ak wrote:Did you make the additional wire connection between stalk and body computer?
My problem is the same. I did everything but the CC is not functional after the PROXY. The final step is to open the body and check for missing components. Didn't have time during holidays but I'll write here when I have more information.
Activated and fully functional except the dashboard led indication.
The problem was weak cable connection on Pin 41.
It was what about I was writing to you in my first private message ...dimitar_ak wrote:Activated and fully functional except the dashboard led indication.
yani wrote:I already know how to activate the CC in 2008+ Grande Punto... This functionality will be available in next release.
However, the log which you posted above is not from a 2008 GP... It is from older GP.
Hello Yani. I want to add CC to my car. I'm using 2008 Grande Punto 1.4 TJEt Sport 120hp. Is it possible with Multiecuscan free version ?
It is impossible.luc wrote:Hello Yani. I want to add CC to my car. I'm using 2008 Grande Punto 1.4 TJEt Sport 120hp. Is it possible with Multiecuscan free version ?
9662621"fiatbravoemotion"]
Ok then is it possible with registered version?
It is impossible.[/quote]luc wrote:Hello Yani. I want to add CC to my car. I'm using 2008 Grande Punto 1.4 TJEt Sport 120hp. Is it possible with Multiecuscan free version ?
