Grande Punto Cruise control aftermarket
Re: Grande Punto Cruise control aftermarket
I already know how to activate the CC in 2008+ Grande Punto... This functionality will be available in next release.
However, the log which you posted above is not from a 2008 GP... It is from older GP.
dimitar_ak
Post by dimitar_ak »
yani wrote:I already know how to activate the CC in 2008+ Grande Punto... This functionality will be available in next release.
Hah, it's a mistery. The log is from my punto march 2008. Anyway you give me an idea how to solve the problem. It should be in the wire connection. Thank you very much.
dimitar_ak
I made a short guide how to disassemble GP dashboard. The guide is in Bulgarian, but I can translate it in English.
http://www.fiat-bg.com/forum/viewtopic. ... 49&start=0
I'll write aditional post after next try to activate the CC. I believe that the PROXI alignment error is thrown because of the mising LED.
dimitar_ak
No again. The LED is activated in Dashboard check but doesn't work in actuators. The Dashboard node still gives error on PROXI if CC is activated and the CC is not working. The next step is to see what's in the BODY computer.
Well, I already told you that your body computer is the older type... So, there is no way for the new function to work with it.
fiatbravoemotion
Post by fiatbravoemotion »
yani wrote:Well, I already told you that your body computer is the older type... So, there is no way for the new function to work with it.
At the same, that old function will not work on 2nd generation of Body units. In some cases this option disabled Blue Me after old proxi onto newer Body unit.
dimitar_ak
Thank you guys. I misunderstood the last Yani's post. So you mean the solution is to change the body with supported one?
fiatbravoemotion
I don't know from what you have an information about nessesary to change of Body unit in Grande Punto <08 to activate CC. Please give me your VIN number...
I don't think that missing led is blocking activation of CC in Body unit. Dashboard is "backup" Body unit, but about this function this device is receiving information from Body and it is simple, Body is sending information to light CC led. Dashboard don't understand this information, because in memory has not this information. It is my opinion, but led on mainboard is not first on all of chain steps in dashsboard. Led is at the end of this chain. If memory don't have information about CC, they don't solder led. But 1% is possible that this led, if you solder it, in dashboard this function will unblocked... If you try solder it you can know more. But for me it is too simply...
dimitar_ak
ZFA19900002056156
The LED is already soldered and nothing changed.
fiatbravoemotion
Checked, just connect and ... it will works after MES.
