Page 256 of 256
Posted: 22 Jun 2025, 19:09
by Rate
Exxagerator wrote: ↑07 Apr 2025, 06:26
Hi Guys
I want to share with You all what I came across when looking here and there how to do proxi alignement in my 2003 punto 1.2 8v.
I've got two interfaces from aliexpress with which I managed to succesfully do proxi alignement:
1) you must desolder from pcb - Big thanks to oskar69 from page number 227
It is this one: OBD2 Car Diagnostic Tool elm 327 HS CAN /MS CAN ELM327 USB V1.5 FTDI/CH340 PIC18F25K80
https://pl.aliexpress.com/item/1005006083281661.html?spm=a2g0o.order_list.order_list_main.143.44591c24s9JzEI&gatewayAdapt=glo2pol
Then desolder 1200 resistor (120 Ohm resistor) between pin 6 and pin 14, it is located near pins for OBDII socket, you will manage to find this
2) you don't need to solder anything: Vgate vLinker FS ELM327
https://pl.aliexpress.com/item/1005005065055828.html?spm=a2g0o.order_list.order_list_main.113.44591c24s9JzEI&gatewayAdapt=glo2pol
I was able to connect with MES and have no problems so far.
Wish you luck
Thank you very much for share info,Vgate vLinker FS ELM327 work excellent on Multiecuscan.
Posted: 24 Jun 2025, 15:26
by hero_1016
Hi Guys
Wish you luck
Dear All
What is meant by desoldering the resistor
remove the resistor leaving the circuit is open?
Or connect the two terminals after removing the resistor?
Thanks in advance
Posted: 26 Jun 2025, 07:35
The resistor has to be REMOVED.
Technically the resistor is a Bus Terminator. All CAN-Bus have to have a termination of 120 ohms. However this termination is already present on the Body Computer so having two terminations kills / reduces the data signal. Hence the need to remove the terminator in the ELM interface.
Posted: 18 Aug 2025, 21:01
by bruba
hola gente, tampoco puedo comunicarme con ecu de abs epb, sera problema de mi obd2? mi obd2 es elm327 hs-pro
si pueden ayudarme agradeceria.
saludos.
![Image]()
Posted: 11 Sep 2025, 04:06
by glp22
Bonjour,
une 2 plus
ELM327 1.4 usb de 2012
voir les photos
R04 à dessouder
lecture bus CAN OK
Cdlt GLP
![Image]()
Posted: 26 Sep 2025, 15:10
by Dybly
glp22 wrote: ↑11 Sep 2025, 04:06
Bonjour,
une 2 plus
voir les photos
R04 à dessouder
lecture bus CAN OK
Cdlt GLP
Bonjour, malheureusement vos images n'apparaissent pas... Un lien peut-être? Merci par avance.
Hello, unfortunately your images are not appearing... Perhaps a link? Thanks in advance.
Posted: 04 Nov 2025, 17:10
by Magg27
This is my ELM327 - one part is missing (I've marked it with an arrow). Could this be causing the connection problem?
Posted: 11 Jan 2026, 12:30
by Bino
Pessoal tenho um Fiat argo 2022. Preciso fazer alinhamento de proxy. Qual obd vcs me indicam ??
Translate by Mod.
Staff I have a Fiat argo 2022. I need to do proxy alignment. Which obd do you indicate me ??
