Tomfarnell1997
Post by Tomfarnell1997 »
Whiley wrote: 24 Apr 2024, 19:19 Sorted buzzed the board and found the 120 ohm resistor connected to 6 and 14, see picture attached, all works now and managed to do dpf reset and connect fully to ecu. I bought this kit off of amazon and for anyone who has this problem and has the red board see picture below of 120 ohm resistor to remove.
Hi Whiley, I have the same circuit board but I'm unsure what to do. There doesn't seem to be a photo attached. Please could you give a bit more advice? Cheers.
naminator2003
Post by naminator2003 »
For my ELM327 USB interface, the 120ohm resistor is located here:
https://ibb.co/0tth1wp
Encircled in blue. Usually between pins 6 and 7 of the CAN transceiver integrated circuit (8 pin SOIC, here named 1044)
Darkburrow
Post by Darkburrow »
Did i buy a Dud, this does not look right at all ? :/
Mine looks nothing like anyone elses on here, is mine a China-fake? It doesnt even say "ELM327" on it.
SME61
Post by SME61 »
Alfaeddy wrote: 11 Jan 2013, 22:14 Hello aurick86
Remove the red marked resistor on your board
and your interface is also capable of Multiecuscan CAN Bus
This helped me, mine board is red but resistor is the same.
Thank you very much. Fiat 500C sport 2014
Venigo
Post by Venigo »
Hi all,
Just registered on this forum to gather some more information about the ELM mod. Only... I can't find any information about the latest Chinese interface. It is the same pcb for the 1.5 and the 2.1 version. It doesn't connect with AlfaOBD / MES, other apps are working (even the elm identifier).
This is the board:
Any idea if there is any resistor that needs to be removed or is it not possible to apply the mod to this device?
Thanks in advance.
gerjsmit
Post by gerjsmit »
Hallo, may I ask as I am not an electronic boffin. You mentioned 2 resistors and 2 capacitors, but in your photos I only see one resistor and capacitor soldered together and the pins it is soldered to on the board are not that clear on the picture? Then it seems you removed R14 so that circuit will be open right? Kindly advise - much appreciated
proostjoost
Post by proostjoost »
Thank you TS Yani!
I backtracked your steps and found the 120 ohm resistor on my PCB too, removed it, and now it works, even without the prescribed CAN termination. I will terminate the CAN lines properly before I attempt coding. Together with the PL2303 driver build by John Stevinson it is working now. I will proceed buying MEC registered.
Jacksonreis
Post by Jacksonreis »
Bom dia!
Tenho uma ELM327 mini OBDII V 1.5, estou tendo problema para conecxão com ECU no Punto ELX 1.4 2010, alguém teria alguma informação?
TRANSLATION BY MOD
Good morning!
I have an ELM327 mini OBDII V 1.5, I'm having trouble for ECU conecsion in Punto ELX 1.4 2010, would anyone have any information?
Exxagerator
Post by Exxagerator »
Hi Guys
I want to share with You all what I came across when looking here and there how to do proxi alignement in my 2003 punto 1.2 8v.
I've got two interfaces from aliexpress with which I managed to succesfully do proxi alignement:
1) you must desolder from pcb - Big thanks to oskar69 from page number 227
It is this one: OBD2 Car Diagnostic Tool elm 327 HS CAN /MS CAN ELM327 USB V1.5 FTDI/CH340 PIC18F25K80
https://pl.aliexpress.com/item/1005006083281661.html?spm=a2g0o.order_list.order_list_main.143.44591c24s9JzEI&gatewayAdapt=glo2pol
Then desolder 1200 resistor (120 Ohm resistor) between pin 6 and pin 14, it is located near pins for OBDII socket, you will manage to find this
2) you don't need to solder anything: Vgate vLinker FS ELM327
https://pl.aliexpress.com/item/1005005065055828.html?spm=a2g0o.order_list.order_list_main.113.44591c24s9JzEI&gatewayAdapt=glo2pol
I was able to connect with MES and have no problems so far.
Wish you luck :D
hero_1016
Post by hero_1016 »
Darkburrow wrote: 08 Jun 2024, 19:35 Did i buy a Dud, this does not look right at all ? :/
I have the same and don't know what to do!
