acgiannopo
Hey guys. I've bought an ELM 327 v1.5 usb dongle from Aliexpress to use it with MultiEcuScan v5.0. The only interface that works with engine ECU is K-line, nothing more. Haven't yet opened it to check if it is trully a 1.5 version. I've tried to test other interfaces and kept responding timeout. Any ideas?
Hello to everyone, i hope someone could help me
I have bought a chinese OBD ELM327 adapter but when i try to do some tests with MES i have this log:
First Test
Second Test
The adapter type is this:
https://it.aliexpress.com/item/1005004095493028.html?spm=a2g0o.order_list.order_list_main.71.23cb3696fUSUHI&gatewayAdapt=glo2ita
I have also tested the adapter with ELM327 Identifier, this is the log:
The adapter works well with AlfaOBD.
Best Regards
Stefano
First Test
RESPONSE: AT?Z?>
RESPONSE: ATI?>
RESPONSE: AT?E0>
RESPONSE: AT?L0>
RESPONSE: AT?H0>
RESPONSE: AT?S?C>
RESPONSE: AT?S0>
RESPONSE: AT?CAF0>
RESPONSE: AT?CFC0>
RESPONSE: ATCR?A 7B0>
RESPONSE: ATSH? 7B0>
RESPONSE: AT?T?1>
RESPONSE: AT?ST41>
RESPONSE: ATBI?>
RESPONSE: AT??>
RESPONSE: ATI?>
Timeout operazione.
ELM327 Identifier 1.16.19
Data scansione=2023-04-23 20:13:26
Nome dispositivo=OBDII
Versione dispositivo (dichiarata)=ELM327 v2.1
Comando Versione Risultato RAW
AT@1 1.0 true AT@1\rOBDII to RS232 Interpreter\r\r>
ATSPA6 1.0 true ATSPA6\rOK\r\r>
ATTPA6 1.0 true ATTPA6\rOK\r\r>
ATTP6 1.0 true ATTP6\rOK\r\r>
ATSP00 1.3 true ATSP00\rOK\r\r>
ATSP6 1.0 true ATSP6\rOK\r\r>
ATAL 1.0 true ATAL\rOK\r\r>
ATNL 1.0 true ATNL\rOK\r\r>
ATAMC 2.0 true ATAMC\rOK\r\r>
ATAMT20 2.0 true ATAMT20\rOK\r\r>
ATRA70 1.3 true ATRA70\rOK\r\r>
ATSR70 1.2 true ATSR70\rOK\r\r>
ATAR 1.2 true ATAR\rOK\r\r>
ATAT0 1.2 true ATAT0\rOK\r\r>
ATAT2 1.2 true ATAT2\rOK\r\r>
ATAT1 1.2 true ATAT1\rOK\r\r>
ATBD 1.0 true ATBD\r00 00 00 00 00 00 00 00 00 00 00 00 00 \r\r>
ATBRT0F 1.2 true ATBRT0F\rOK\r\r>
ATC0 2.3 false ATC0\r?\r\r>
ATC1 2.3 false ATC1\r?\r\r>
ATCAF0 1.0 true ATCAF0\rOK\r\r>
ATCAF1 1.0 true ATCAF1\rOK\r\r>
ATCEA04 1.4 true ATCEA04\rOK\r\r>
ATCERF1 2.2 true ATCERF1\rOK\r\r>
ATCEA 1.4 true ATCEA\rOK\r\r>
ATCF00000111 1.0 true ATCF00000111\rOK\r\r>
ATCF111 1.0 true ATCF111\rOK\r\r>
ATCFC0 1.0 true ATCFC0\rOK\r\r>
ATCFC1 1.0 true ATCFC1\rOK\r\r>
ATCM00000111 1.0 true ATCM00000111\rOK\r\r>
ATCM111 1.0 true ATCM111\rOK\r\r>
ATCP18 1.0 true ATCP18\rOK\r\r>
ATCRA7C0 1.3 true ATCRA7C0\rOK\r\r>
ATCRA000007C0 1.3 true ATCRA000007C0\rOK\r\r>
ATCRA 1.4b true NO DATA\r\r>
ATCRA 1.4b true ATCRA\rOK\r\r>
ATCS 1.0 true ATCS\rR:00 \r\r>
ATCSM0 1.4b true ATCSM0\rOK\r\r>
ATCSM1 1.4b true ATCSM1\rOK\r\r>
ATCTM5 2.1 true ATCTM5\rOK\r\r>
ATCTM1 2.1 true ATCTM1\rOK\r\r>
ATCV0000 1.4 true ATCV0000\rOK\r\r>
ATD1 1.3 true ATD1\rOK\r\r>
ATD0 1.3 true ATD0\rOK\r\r>
ATDP 1.0 true ATDP\rAUTO, \r\r>
ATDPN 1.0 true ATDPN\rA5\r\r>
ATE0 1.0 true ATE0\rOK\r\r>
ATE1 1.0 true OK\r\r>
ATFCSD001122 1.1 true ATFCSD001122\rOK\r\r>
ATFCSH000007B0 1.1 true ATFCSH000007B0\rOK\r\r>
ATFCSH7B0 1.1 true ATFCSH7B0\rOK\r\r>
ATFCSM1 1.1 true ATFCSM1\rOK\r\r>
ATFCSM2 1.1 true ATFCSM2\rOK\r\r>
ATFCSM8 2.3 false ATFCSM8\r?\r\r>
ATFCSM9 2.3 false ATFCSM9\r?\r\r>
ATFCSMA 2.3 false ATFCSMA\r?\r\r>
ATFCSM0 1.1 true ATFCSM0\rOK\r\r>
ATFE 1.3a true ATFE\rOK\r\r>
ATFT10 2.3 false ATFT10\r?\r\r>
ATFT 2.3 false ATFT\r?\r\r>
ATH0 1.0 true ATH0\rOK\r\r>
ATH1 1.0 true ATH1\rOK\r\r>
ATI 1.0 true ATI\rELM327 v2.1\r\r>
ATIA 2.3 false ATIA\rELM327 v2.1\r\r>
ATIB10 1.0 true ATIB10\rKBusBaud=10400 OK\r\r>
ATIB12 2.2 true ATIB12\rKBusBaud=10400 OK\r\r>
ATIB15 2.2 true ATIB15\rKBusBaud=10400 OK\r\r>
ATIB48 1.4 true ATIB48\rKBusBaud=4800 OK\r\r>
ATIB96 1.0 true ATIB96\rKBusBaud=10400 OK\r\r>
ATIFRS 1.2 true ATIFRS\rOK\r\r>
ATIFRH 1.2 true ATIFRH\rOK\r\r>
ATIFR0 1.2 true ATIFR0\rOK\r\r>
ATIFR2 1.2 true ATIFR2\rOK\r\r>
ATIFR1 1.2 true ATIFR1\rOK\r\r>
ATIFR6 2.2 true ATIFR6\rOK\r\r>
ATIFR5 2.2 true ATIFR5\rOK\r\r>
ATIFR4 2.2 true ATIFR4\rOK\r\r>
ATIGN 1.4 true ATIGN\rON\r\r>
ATIIA7A 1.2 true ATIIA7A\rOK\r\r>
ATJS 1.3 true ATJS\rOK\r\r>
ATJE 1.3 true ATJE\rOK\r\r>
ATJHF0 1.4b true ATJHF0\rOK\r\r>
ATJHF1 1.4b true ATJHF1\rOK\r\r>
ATJTM5 1.4b true ATJTM5\rOK\r\r>
ATJTM1 1.4b true ATJTM1\rOK\r\r>
ATKW 1.3 true ATKW\r1:-- 2:-->
ATKW0 1.2 true ATKW0\r1:-- 2:-->
ATKW1 1.2 true ATKW1\r1:-- 2:-->
ATL0 1.0 true ATL0\rOK\r\r>
ATL1 1.0 true ATL1\rOK\r\n\r\n>
ATM1 1.0 true ATM1\r\nOK\r\n\r\n>
ATM0 1.0 true ATM0\r\nOK\r\n\r\n>
ATPPFFON 1.1 true ATPPFFON\r\nOK\r\n\r\n>
ATPPFFOFF 1.1 true ATPPFFOFF\r\nOK\r\n\r\n>
ATR0 1.0 true ATR0\r\nOK\r\n\r\n>
ATR1 1.0 true ATR1\r\nOK\r\n\r\n>
ATRV 1.0 true ATRV\r\n11.6V\r\n\r\n>
ATS0 1.3 true ATS0\r\nOK\r\n\r\n>
ATS1 1.3 true ATS1\r\nOK\r\n\r\n>
ATSDFF 1.4 true ATSDFF\r\nOK\r\n\r\n>
ATRD 1.4 true ATRD\r\nFF\r\n\r\n>
ATSH000007E0 2.0 true ATSH000007E0\r\nOK\r\n\r\n>
ATSHA848F1 1.0 true ATSHA848F1\r\nOK\r\n\r\n>
ATSH7B0 1.0 true ATSH7B0\r\nOK\r\n\r\n>
ATST32 1.0 true ATST32\r\nOK\r\n\r\n>
ATSWFF 1.0 true ATSWFF\r\nOK\r\n\r\n>
ATTAF9 1.4 true ATTAF9\r\nOK\r\n\r\n>
ATV1 1.3 true ATV1\r\nOK\r\n\r\n>
ATV0 1.3 true ATV0\r\nOK\r\n\r\n>
ATWMC133F13E 1.0 true ATWMC133F13E\r\nOK\r\n\r\n>
ATPC 1.0 true ATPC\r\nOK\r\n\r\n>
ATWS 1.0 true ATWS\r\n\r\rELM327 v2.1\r\n\r\n\r\n>
ATD 1.0 true ATD\r\nOK\r\r>
ATZ 1.0 true ATZ\r\r\rELM327 v2.1\r\r>
Best Regards
Stefano
I share this link in case you need it.
https://es.aliexpress.com/item/1005004443781867.html?spm=a2g0o.order_list.order_list_main.10.74a8194d4wMkBS&gatewayAdapt=glo2esp
I bought this OBDII interface, and it works correctly for me, there are no changes to make it work.
It only cost me €18, I tried it on my Fiat Grande Punto 1.2, and it read the control units without problems.
The first thing I did was read which switchboards it had, and then I was accessing all of them without any problem.
In the attached image, highlighted in green, you can see the control units that I have, for the body computer you have to use the yellow adapter.
Hi,Artemiop wrote: ↑04 May 2023, 12:23 Hello
I just bought this cable as you suggested, however when connecting to the service module, I'm getting a Can Bus Error. I've tried a couple of extra settings in MES but then I'm getting a timeout so I guess the settings are ok. Could you share your settings/drivers?
Thanks!
Kim
Is this issue also at the ELM 327 WiFi OBD Adapter?
Thanks in advance!
Thanks in advance!
Hi, had a problem with my elm on a Fiat panda 1,1 8V MY2006
CAN problem when i tried dashboard connect or other modules apart the engine
I removed the 120 ohm resistor on my PCB and it works like a charm now .
Hi I just got the same ELM327 by Viecar, can you expaing about the jumpers, I can't understand it. Thanlk you.welton wrote: ↑29 Aug 2021, 17:11 I have viecar Bluetooth 4.0 OBD2 protocol 1.5.
I need remove resistor 120 ohm in position image atached and jumper betwen pins 1,3,7,8 and 9,11, 12, dont make jumper in pins 1 and 9.
My car is Siena 1.0 year 2014 Brazil.
Instrument Panel Continental and engine module G4F.
I have free access from ALL modules, after modification in OBD with multiecuscan and AlfaOBD.![]()
For Proxy aligment i select Strada 1.4 in multiecuscan, all rigth in my car.
Follow the link in Aliexpress, delivery in 13 days to Brazil.
R$ 44,74 25%de desconto | Viecar-leitor de código obd2, diagnóstico via bluetooth 4.0, elm327, ios, android, pc elm 327 v1.5, interface de diagnóstico
OBD Viecar Link
https://a.aliexpress.com/_msVSbeT
Image viecar resistor 120 ohm
https://ibb.co/d74xQXJ
Image Need Jumper
https://ibb.co/TryJP6D
Good Luck for ALL.
Forget about jumpers. Use adapters especially if you wanna use Proxy Alignament.
Jumper just connect together some pins to make the interface comunicate with controlers on other pins the 7 (k-lin) or 6-14(CAN BUS)
The best ways is to use adpaters or as me an all-in-one adpater that let you manually multiplexing without changing the adpater by hand.
Read here: http://forum.multiecuscan.net/viewtopic.php?f=5&t=9532
Hello, I have just bought ELM327 and new to Multiecuscan so I have a few questions.
First of all, my elm327 doesn't look the same as the others I've seen here on the forum, so I wonder which resistor should I remove.
Some other questions, why is the resistor being removed, is it to access can-modules? One other question is the ELM327 usable without the adapter cables & removing resistor. Because I got some errors trying connecting such as "WARNING: This interface is not compatible with ELM 327 1.3! Will not connect to any CAN module." and also problems when testing the connection in settings.
https://ibb.co/kyhRwct
https://ibb.co/bWPt2mF
https://ibb.co/Db0BHRC
All help and answers are appreicated since I'm all noob to this.
Thanks in advance.
Thanks in advance.
If you do not remove the resistor you will not be able to connect to CAN BUS controlers.
So use a multimeter ( ohmeter ) to check if the resistor is there 120 ohm between CAN BUS pins 6-14.
If there is you have to remove the resistor. If there isn't any resistance between OBD2 pins 6-14 ( on your interface ) you haven't that resistor.
Adaptors are used to connect to other CAN BUS controlers on other pins as 3-11, 12-13, 1-9 and other k-line controlers then one on pin 7
No adpators you will be able to connect only on CAN BUS pins 6-14 and k-lin pin 7.
