Page 26 of 257
Posted: 07 Mar 2012, 14:14
by mattydr67
Yes you got right all VAg cars have engine on k-line
Opel it is good or other new car on CAN
Posted: 07 Mar 2012, 14:28
by stilo16
mattydr67 wrote:Can you connect into the CAN controlers?
As I see in your pics your tool it is 1.5
The chinese made this version 1.5 which can be version 1.3, 1.4 or in the bad case 1.2
Version 1.2 it is not support by the FES
So in this case you have to go in other CAN car and try to connect using a softwear for ELM327
And if you can connect in a car based on CAn, VW Golf 5, Skoda Octavia II, Ople Insignia, Opel Vectra C/Signium or Astra H etc in this case you have bad luck the tool is version 1.2
Which are the can controllers? I can connect to Engine, Body, Service Interval.. and CANNOT connect to ABS and Airbag
Posted: 07 Mar 2012, 15:42
by mattydr67
That's good
ABS it is on PIN 1 you can solder a wire from PIN 7 to Pin 1 and you'll be able to conect to ABS or use the adaptor1
For Airbag on K-line which is on pin 3 even you solder a wire between pin 7 to pin 3 you'll not be able to connect on it becasue the ELM327 dosen't suport Airbags on K-line just the one on CAN
For K-line Airbags you need a Vag kkl interface or a OBDKey interface with the adaptor1
Posted: 07 Mar 2012, 18:44
by stilo16
mattydr67 wrote:That's good
I saw the diagrams here
http://www.multiecuscan.net/SupportedVehiclesList.aspx but I have a question: where can I get another connector so that I can integrate microswitches on it. I assume by soldering the wires as you suggested will disable other modules is that right? Thanks
Posted: 07 Mar 2012, 19:57
by mattydr67
No mate in your tool you can solder toghether pin 1, 7 and 12
But as I told you Airbags it isn't covered by the ELM327
You can use a scwitch and a VAG kkl
for the k-line controler and keep your ELM just for CAN controlers
This if you dosen't want to have separate adaptors
Posted: 07 Mar 2012, 20:29
by stilo16
mattydr67 wrote:No mate in your tool you can solder toghether pin 1, 7 and 12
Ah, I got it now
Thanks a lot.. I was really surprised how de-soldering that resistor has cured it. I will purchase that VAG com cable then. I am eager to try the ABS as I saw a counter of how many times it activated. In some previous version of FES I also saw a max rev counter where can I find that one in the new version?
Posted: 07 Mar 2012, 20:41
by mattydr67
ABS you can try it with you tool ELM
Just open it up and solder the pin 7 with pin4 together
You'll see that you can connect in it
Just for Airbag you need another tool a KKL interface
but for the all others the ELM it is good enough
Posted: 07 Mar 2012, 20:45
by stilo16
mattydr67 wrote:ABS you can try it with you tool ELM
So I connect pins 7 and 4 - I read Airbag and I am still able to connect to all other CAN modules?
Posted: 07 Mar 2012, 23:05
by mattydr67
Sorry
Solder together pins 1,7 and 12
For controlers on k-line
CAN use other pins and you said that it works
For Airbag you need another tool
Posted: 13 Mar 2012, 12:50
by pinuccio
Hello everyone, sorry for my English but I am Italian.
They are holding a spear Ypsilon 1.3 Mjet of 2008.
I wanted to know what cables I need to maximize the potential of multiecuscan.
thanks
