Page 245 of 257
Posted: 03 Feb 2020, 22:46
by ivanov156
Mark1 wrote: ↑29 Jan 2020, 12:04
Hello everyone!
I have read and experimented a lot with the best value for money tool.
So far I have come to this tool: https://www.aliexpress.com/item/32862479065.html?spm=a2g0s.9042311.0.0.5d824c4dJTLVmL
I've tested many of the same looks, both old and new, and foror at similar prices , ONLY this device seems to be good.
(So far I've only tested it with key programming radio and immo)
I hope I help with it, so I wrote this so that everyone doesn't buy as much cheap equipment as I do.
BR.
I have the same cable as yours. I have MES 3.6 cracked and working fine with VAG COM cable. To be able to connect to the Delphi electric power steering of my Punto MK2 i need the ELM 327. When i adjust the port settings from the device manager (using FTDI virtual com port) but when i try to connect MES cant find the com port, or in some cases the error is SUITABLE INTERFACE NOT FOUND. I need to mention that i did not installed anything before try to use the ELM327 cable (the small disc with the cable was damaged). Someone can help?
Posted: 04 Feb 2020, 12:21
ivanov156 wrote: ↑03 Feb 2020, 22:46
Please do not expect
official help as I bring your attention to this site's official statement:
"PLEASE NOTE: Our email is flooded with complaints for incorrect operation and virus problems from people who use manipulated copies of Multiecuscan (bought from Chinese web sites and elsewhere). We cannot take any responsibility for incorrect operation of non-genuine software and the problems it may cause to your computer and vehicle. We will not reply to any email from users of this software and will not provide any support to them.
The genuine software has digital signature and can be downloaded from this web site. Licenses for the software can be purchased from here or from one of the distributors."
Posted: 10 Feb 2020, 19:17
by GeorgeSmyrlis
Hello guys, i have bought the MES (50€ licence) and i have the elm327 diag on photos. I connnect to engine on Punto mk2 just fine and i have all the tests OK but i cannot connect to bcm or dashboard to make proxi alignement, It gives me canbus error. Can someone help me on what resistors or something else i need to change to make it work? Thanks, George from greece.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/I6uN7fa"><a href="//imgur.com/a/I6uN7fa"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
Posted: 07 Mar 2020, 21:55
by jandish
Тоже купил жёлтый кабель для Фиата .(Добло ,бензин,1.4 77 л.с,2008)Элм 327 с кнопкой v.1.5
по блютузу.Нет соединения с ЭБУ.Прозвонил контакты между 6 и 14 контактом .120 ом. Удалил резистор R 02.
Все равно не работает.И альфаОвд ,и Торкью, и Автодоктор и много других программ не помогли.
Posted: 07 Mar 2020, 22:01
by jandish
handynoturno wrote: ↑09 Jan 2020, 13:55
Guys, first make sure that the interface used is actually implemented with the 121ohms resistor
check below:
https://www.youtube.com/watch?v=emzyE-zkGmw
resistor that must be removed:
https://ibb.co/tczXLW2
After checking that between pins 6 and 14
is showing 120 ohms on the multimeter, look for it on the board and remove it
Sorry my bad english.
Сделал как написали ,удалил 120 ом между 6 и 14 ,R 02.Все равно не работает.
Posted: 08 Mar 2020, 18:38
by jandish
Наконец то сегодня elm 327 блютуз в 1.5.58 с кнопкой включения зработала на Фиате Добло ,бензин,1.4,77 л.с.После изучения опыта других в инете ,помогла простая перемычка между 3 м и 7 м контактом в разъёме сканера.Хотя там на белорусском сайте предлагали ещё и 1 контакт с 3 м и 7 м вместе соединить. Проводок накинул просто сверху .А программа из всех загруженных на телефон, только Alfa OBD пошла .А так желтый переходник ,его ещё сколько дожидался с Али и отключение резистора в 120 ом (R 02 ) между 6 м и 14 м контактом сканера не помогли .Соединение осуществилось после нажатия- Соединить -в разделе блок управления и предварительного выбора Эбу - Marelli engine 1.4 8v
Хотел исправить слово elm .Не даёт программа это здесь сделать.Когда захожу в редактирование все правильно написано.А как отправляю ,то уже видоизменяется автоматически ((
Итог- Фиату нужна перемычка между 3 м и 7 м контактами и программа Альфа ОВД
Posted: 11 Mar 2020, 09:50
by Crazyj
Alfred Romero wrote: ↑11 Nov 2019, 12:34
Hello. I have Viecar bluetooth 4.0 OBD2 scanner and can connect to the engine module only. All other modules dont connect. I am using AlfaOBD paid version on my Android phone. Can someone help me to detect which resistor should be removed if possible?
Photos here:
https://ibb.co/KLR9PLr
https://ibb.co/ZJkXTc4
You need to remove r2, in your second photo it is on the top left just above u1. Ot has r2 on the left of it and r46 on the right. I have the same adaptor and have just done this after tracing with a multimeter and now I can connect to all can modules.
Posted: 13 Mar 2020, 19:02
by szelod9
Hi guys.
I've bought the following OBD to read my 2012 Giulietta:
https://www.ebay.com/itm/FIAT-Special-ELM327-Bluetooth-Modifiziert-fur-Alfa-Romeo-Lancia-CAN-BUS-OBD2/273445603924?_trkparms=aid%3D1110002%26algo%3DSPLICE.SOI%26ao%3D1%26asc%3D225118%26meid%3D708c6fba2ede4ae0a2a55884cb6dab74%26pid%3D100891%26rk%3D1%26rkt%3D6%26mehot%3Dpp%26sd%3D282550542432%26itm%3D273445603924%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DSellersOtherItemsV2&_trksid=p2332490.c100891.m5206
I managed to connect the OBD to my laptop through bluetooth. When I start MES and try to connect interface, "Timeout" shows. I tried all avaliable speeds, and COMs are on the lowest position. I wasn't able to install Net Framework 3.5.
What should I do?
Win10 x64
MES 3.9 Registered
Posted: 11 Apr 2020, 13:40
by Mozgus87
Good afternoon everyone, i bought the following ELM327 interface i tried to connect with this interface to my car (Alfa Giulietta 2017 1.6tdi) but it doesn't work. i need to reset the service message on my car with MES (i have just buy yellow cable A3). i already read every page of this forum, but i found a obd similar to mine nut with no answer. I have remove r02 121ohm and solder the new termination circuit with two resistors of 100 Ohm and 2 capacitors of 560 pF
Could please any of you help me?
thank you in advance for your support, i'm waiting for you.
Posted: 16 Apr 2020, 08:19
by Fran.M
Hello, I am new here I have a Fiat Ducato x-250 2.3 Multiget that I want to install the fog lamps with which the Body must be activated, I have bought the ELM327 1.4 and the intermediate colored connectors, once connected and doing the test on the multiscan 4.6R1 Free, does not allow me to connect in any module, however with the scanner directly with the elm327 if it connects.
Can someone tell me say the ELM327 that I have is fine ??
I am new and I do not know how the photos are inserted, it gives me an error when I attach them
