According to the original post of this thread the resistance that you have to change is 120 Ohm, not 100 Ohm. You have to change the 120 Ohm resistor for a 100 Ohm one. And you have also to change some capacitors but I don't understand how that part works.
Here you have the quote:
yani wrote: ↑12 Sep 2010, 20:50 The problem is actually in the CAN termination method used in these interfaces - they use one 120 Ohm resistor connected between CAN-L and CAN-H.
According to the ELM327 datasheet the proper termination is to use 100 Ohm resistor on each of the 2 lines connected to ground through a 560 pF capacitor (see the picture below).
So i just got two 100 Ohm resistors and two capacitors of 560 pF and fixed my interface as shows below. And it WORKS flawlessly now.
