lucapi
Post by lucapi »
Hello everybody,
I buy from aliexpress one obd2 cable 1.5a but MES show me error to try test
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
RESPONSE: ATL0
RESPONSE: ATH0
RESPONSE: ATSPC
RESPONSE: ATS0
RESPONSE: ATCAF0
RESPONSE: ATCFC0
RESPONSE: ATCRA 7B0
RESPONSE: ATSH 7B0
RESPONSE: ATAT1
RESPONSE: ATST41
RESPONSE: ATBI
have suggestion for resolve this problem?
dommy
Post by dommy »
Hello everybody!
What resistor should remove ?!
fxiat500
Post by fxiat500 »
I have connected an unmodified wifi ELM to my fiat 500 convertible. From the licenced software, I can access abs for exemple. It's connected.
Now I need to access the convertible ecu to reset it and face 2 problems:
1* it is not wired inside but only hard pins an printed board. Can I connect 1 and 9 without cutting 6 and 14 ?
2* My multimeter read 9 Ohm between 6 and 14 but I see only a 120 Ohm resistor close to the ELM chip. Can I assume its my multimeter fault (9,1 Ohm on the 200 scale and 1 on the 2000 scale, not a scaling problem something worst)
My picture is a mess, my focusing dont work.
Thanks,
FX
fxiat500
Post by fxiat500 »
Tested both side of the 121 ohm resistor close to LM chip (between two pins in the middle on one side of the chip), pin 6 and pin 14 for the plug are connected there. Still read 10Ohm on my cheap multimeter, there come my worry from so OK.
The hard pin were not that hard, I cut two of them easily. Most difficult was to find a little pliers. OK
Had'nt the time to remove the resistor yet. For this wifi 1,5 ELM not wired inside so far so good.
fxiat500
Post by fxiat500 »
Not good
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
RESPONSE:
vince59
Post by vince59 »
HI I have MES installed on two different notebooks.
An old one with XP. MES 3.6 and 3.7 is able to connect to the car with elm 327 clone and proper adpater cable BUT does not complete service reset while connects to other ECUs. The only functin that is accomplished is the DPF timer reset after oil change, but not working on other parameters.
Another PC is a new one with win10 but MES fails to connect for service reset at all.
Any help, suggestion from you?
fxiat500
Post by fxiat500 »
Windows 64bit is allowed for the ELM327 ? I saw at least one ELM's ad with "'windows 32 bit only"'.
PedroFirmino
Post by PedroFirmino »
Olá, Sou do Brasil e tenho uma interface ELM 327 1.5a de metal, Já foi removido o resistor 02 mas perdeu a comunicação com Alfaobd .
tem que por um resistor de 100 ohm ? o que estava era de 10k ohm . antes comunicava somente com o motor e agora não comunica mais.
Meu carro é um FIAT UNO VIVACE 2012 MOTOR EVO 1.0 IAW7GF
ELM 327.jpg (3.58 MiB) Viewed 29132 times
PedroFirmino
Olá, tenho a mesma interface do h3nriquee.
E já foi removido o resistor 2 mas não tive nenhuma comunicação com o Alfa obd
Uno motor evo IAW7GF. antes com o resistor comunicava agora não comunica. o que pode ser??
Obrigado.
ELM 327.jpg (3.58 MiB) Viewed 29661 times
AlexHF
Post by AlexHF »
Hi there fans, I have a problem with this Chinese ELM 327 bluetooth adapter. Everywhere the test is ok, but at the end it says it can not connect. Is there a way to go, or I will need another. Thanks!
