Bumb
Post by Bumb »
Hello i bought elm 327 1.5a and i first i thought is the driver problems i didn't know unless i saw this thread.
I cant pass the last test on Multiecuscan v3.1.
U can see the problem is it in the second picture
I tried with different ports speeds and its fails in the first test.
Also when i connect to the car its says also that operation has timedout and check ports and cable...
Doi have to remove the resistor ?
magic_fingers
Post by magic_fingers »
Can anybody help me identify the wrong resistor on my adapter board? I'm having trouble with it.
Car is an alfa 159 1.9jtdm 150
cxem
Post by cxem »
Multiecuscan
CAN pin 6 and pin 14
Remove resistor 120 ohm
Video:
https://www.youtube.com/watch?v=emzyE-zkGmw
Perfezionista
Post by Perfezionista »
Alfaeddy wrote:...
This one
http://www.ebay.de/itm/152303739535?_tr ... EBIDX%3AIT
Hello, I bought it on your recommendation and I am unsure with the functionality. We tried to use the interface on our 2008 Fiat Bravo 1.4 T-jet. If the interface is plugged in, all warning lights on the dashboard are ON and the engine coolant temperature gauge does not show - remains at start position. If it is not connected, everything is normal, lights go off after a few seconds and the temperature gauge moves to the corresponding position.
Is the interface ok? It is our first FIAT..
Thank you
Perfezionista
I played with an old KL interface little bit and found out the AutoDia E327 interface has defective the FT-CAN (pins 2+10). It somehow cripples CAN bus of the car so ECUs store errors of the CAN. Supplier KWP2000 (ebay diadig) have not responded so far, so I cannot recommend purchasing it. So if you connect the interface to your car and all lights are on, do not go off, the interface is not good.
https://ibb.co/ijuybF
I would not say that an interface is synonymous mal mal !!
But I know some who bought this ELM and have no problems with it.
Otherwise one should buy the OBDkey interface or here the complete package
With the CANtie Interface !! At a completely different price
At pin 2 + 10 is not a bus or is your Fiat not from Europe ??
Since these pins are used for the SAE1850 protocol.
If your interface is broken you can return it.
Perfezionista
Alfaeddy wrote:Hello
Hello Eddy, thanks for response. The interface has connected pins 2 and 10, which according to http://marco.guardigli.it/2010/10/hacking-your-car.html provide FT-CAN (probably B-CAN?, also http://www.alfaobd.com/AlfaOBD_Android_Help.pdf mentions Bus). It confirms errors related to CANBUS if it is connected. You are right Interface is cheap, so it is easier to disconnect these pins inside.
I can unfortunately not follow your information? ;)
Again, PIN 2 + 10 is not the B-Can
This is at Pin 1 + 9
Pin 2 + 10 is for another protocol (SAE 1850)
I have written this here
gurava
Post by gurava »
Hello!
my avto is Fiat Panda 2007 year 1.2
adapter is usb elm327 (ftdi chip) with fiatecuscan program
I can see only engine and Gearbox selespeed cfc 228f
Can anybody help me - where is resistor that must be dissassembled?
cxem
Post by cxem »
Here are:
