Page 216 of 257
Posted: 11 Jan 2017, 20:12
Hello LukasCA
Even without modification you should be able to connect to the engine control unit with the interface.
The resistor may only cause problems for CAN bus controllers.
And the motor control of the 159 is not read via CAN bus.
Which driver was installed
You have established all the settings
What is the interface test in Multiecuscan?
Posted: 11 Jan 2017, 22:52
by Alex2011fiat
I have this ELM327 v1.5 Wifi and I can't connect to CAN interfaces (Body). Only engine.
The car is Fiat Stilo.
It's the same problem with a resistor? Which one please?
Thanks a lot!!!
Posted: 11 Jan 2017, 23:20
Hallo
It is the Resistor R1 with the Number 121
´Greeting Eddy
Posted: 12 Jan 2017, 15:55
by obdspecialist
No resistor to detach or replace
Buy this one and you get into 100% ECUs of FIAT GROUP
http://www.obdspecialist.it/prodotto-14 ... -FREE.aspx
Posted: 12 Jan 2017, 19:13
@ obdspecalist
This one also
http://www.ebay.de/itm/152303738760?_tr ... EBIDX%3AIT
and to an better price
Posted: 14 Jan 2017, 18:48
by GAlt
Hello guys, i have chinese Elm327 Bluetooth, but some 2016 version
i doubt it can be done to connect with CAN, even to see the board, but although i will post picture of the board if someone know something?
Best Regards
Posted: 14 Jan 2017, 22:03
Hello Galt
Make an Interface Test with Multiecuscan
and post an Screen with an Image
On your Board can´t find an Bridge Resistor
the Motor ecu ist read not with CAN Bus
Also your connect must with no one modifikation
Posted: 15 Jan 2017, 14:34
by GAlt
Alfaeddy wrote:Hello Galt
RESPONSE: ATZ
ELM327 v1.5>
ELM327 v1.5>
RESPONSE: ATE0?>
RESPONSE: ATL0?>
RESPONSE: ATH0?>
RESPONSE: ATSPC?>
RESPONSE: ATS0?>
RESPONSE: ATCAF0?>
RESPONSE: ATCFC0?>
RESPONSE: ATCRA 7B0?>
RESPONSE: ATSH 7B0?>
RESPONSE: ATAT1
OK>
RESPONSE: ATST41?>
RESPONSE: ATBI?>
This is my test. This warning in the end i have and in my another WiFi Elm, but there is no problem with CAN, but this....
p.s. I know that engine is not on CAN
Posted: 15 Jan 2017, 20:17
Hello Galt
I thought it already this interface is not compatible with MES and also AlfaOBD
There are only a few v1.5 ELM interfaces that work.
This has nothing to do with a bridge resistor.
Posted: 16 Jan 2017, 10:41
by GAlt
Thanks a lot anyway Eddy. I thought that v1.5 will not be a problem, becouse my WiFi version is also 1.5 and do not have this problem, but anyway...which version of bluetooth is best?
