Double_Faster
Post by Double_Faster »
Alfaeddy wrote:
Double_Faster wrote:Dear people,
I have a Brazilian Fiat Punto Attractive 2013/2014 and Multiecuscan 3.2. I bought generic Wifi OBDII V.1.5. I tested scan and receive "Magneti Marelli IAW 7GF Injection" ISO Code: CD 85 9E 8C 51. Ok, I conected but I cant conect in Service, I receive error ECU.. This is a resistor problem?
http://img.photobucket.com/albums/v497/ ... bucger.jpg
http://img.photobucket.com/albums/v497/ ... thxwus.jpg
http://img.photobucket.com/albums/v497/ ... k4apmj.jpg
http://img.photobucket.com/albums/v497/ ... p6hllo.jpg
Anybody can help me?
Is your interface with MES Komptibel?
Make times a interface Test with MES
It is compatible with MES remove R1 on the back of the board
and try again
remember, use yellow adapter for the service !!
Thank´s
Hi Alfaeddy, Sorry for delay. In this weekend I remove R1(121) resistors between pins 5 and 6 and now I have this result:
Can you help me?
Thank´s
eVinicius
Post by eVinicius »
Hello all! Again...
Sorry for delay... :(
I have a Fiat Stilo 1.8 8v 2009 in Brazil , a ELM 327 1.5a USB and Multiecuscan 3.0:
The result of Test interface:
RESPONSE: ATZ
ELM327 v1.5
Delphi injection Info is ok:
Result of Scan function:
Result of Scan DTC function:
But I can not use the functions:
"CAN Setup Proxi..." in "Body" section:
"Instrument painel Visteon" in the "Dashboard" section:
"Driver seat lear" in "Other" section:
"Service internal reset" in "Service" section:
and others functions...
Images of the my ELM 327:
I need to remove some resistor to succeed in connection with these modules?
Thank's all!
Knallfrosch wrote:Hello,
I have a problem with Multiecuscan and my Interface.
I use this interface: http://www.ebay.de/itm/ELM327-USB-V1-5- ... 2883?hash= item33a5e111c3: g: 0OcAAOSw3ydVpMlp
The connection to the ECU works. Clear error in the ECU works.
When I perform SCAN (F11), comes the answer "DONE".
But there are no modules appear.
And when I select a parameter, the Connection disconnects completely.
The interface use the drivers: Prolific USB to Serial Comm Port 3.2.0.0 (Windows 10)
The setting in the device manager I have changed from 16 to 1
Does anyone know the problem?
Do I need to remove the 120 ohm resistor in the interface?
Thank you very much.
greetings
PS: The Test from the Interface:
RESPONSE: ATZ
ELM327 v1.5
ELM327 v1.5
And then ???
The test is not finished!
Which Car ??
eVinicius wrote:Hello all! Again...
RESPONSE: ATZ
ELM327 v1.5
Thank's all!
Right Side from the chip (MCP2551) is a resistor (1200)
this you have to remove
and try again
Thank´s
Can you help me?
Thank´s
Have you made all settings ???
Driver ??
Latency Time ??
Then I do not know
may perhaps be the Punto for Brazil any other software in the ECU
loaded which is not fully recognized by Multiecuscan.
eVinicius
Post by eVinicius »
Thank you!
I removed the mentioned transistor and had success in the proxy alignment procedure!
Only I could not disable the beeper seat belt, but this requirement was minimal.
Thanks a lot for the help!
Thank you!
my pleasure
lonerunner
Post by lonerunner »
I took apart my diagnostic tool and it doesn't look at all like the other tools, this is how it looks, what resistors do i need to remove to make it work with my Alfa Romeo 147
Hello Lonerunner
Do you remove the red marked Resistor
Then you can read the CAN Bus Protokoll
http://www.bilder-upload.eu/show.php?fi ... 779301.jpg
lonerunner
Thanks Alfaeddy, i did not remove R2 resistor, i will try to remove it and try it out to see if it works. I actually found that PacBoy have the same interface as i do on this thread on page 208, and the same error when try to pass test
http://www.jpeg.cz/images/2016/08/09/rXiy.jpg
So i didn't want to remove any resistors until i get response from someone.
Btw, this is CH340 chipset and i have it tested and working with that driver on Seat car.
