What kind of vehicle you want to read with Multiecuscan?
2001 Alfa 147 Selespeed.Alfaeddy wrote:Hello
I don't know what the story is now
I am able to connect to almost everything, besides boot, if going to drivers door node, it lets me test all actuators, but when executing boot, it says EXECUTION FAILED.
Proxi allignment hangs for a while but then eventually says FAILED.
at least the odometer stopped flashing
Then you have no problem with your interface
If it works for service, setup CAN, CAN info etc.
Because only in these controls, the CAN protocol is used.
ELM interface to the ECU all work
The proxy is probably raking in a setting error
I've read a few months ago with 147 and could
my interface access to everything.
Only to control the boot I could not get a connection,
I do not know why?
I do not know why?
Thankd Eddy, I also read somewhere now that it might be the FEC software version 2.6.1 that has a bug, just waiting on a reply from someone to confirm this.
Why not install version 3.3 then?gerryd wrote:Thankd Eddy, I also read somewhere now that it might be the FEC software version 2.6.1 that has a bug, just waiting on a reply from someone to confirm this.
Maybe he dosen't know that now it is FES3.3 released or maybe he use a cracked version.
That FES 2.6.1 modified it is a crap.
Use just licensed version of FES.
I have a valid copy of 2.6.1, maybe I should just buy 3.3, anyone know what it costs more or less?Juggers2k wrote:Why not install version 3.3 then?gerryd wrote:Thankd Eddy, I also read somewhere now that it might be the FEC software version 2.6.1 that has a bug, just waiting on a reply from someone to confirm this.
any idea why when I do a scan does it not pick up the Boot Node under other?
Bosch Motronic Me7.3.1 EOBD Injection (Outside EU version)
ISO Code: 7C 86 9E 80 75
ABS
Bosch ABS 5.7 VDC
ISO Code: 25 86 8C 19 25
Gearbox
Marelli SELESPEED CFC208F Automatic Gearbox
ISO Code: BC 07 02 80 1A
Body
Marelli Body Computer
ISO Code: 40 83 8A 80 A2
Dashboard
Mannesman VDO Instrument Panel
ISO Code: 32 83 08 80 92
Climate control
Delphi climate control (Dual zone)
ISO Code: 34 83 01 19 26
Other
Driver's Door (TRW)
ISO Code: 86 07 02 19 FD
COMPLETED
Hello Gerryd
2.6.1 If you have a valid license but you can simply
newer version to install?
Last summer I visited a friend who had a
cracked Versionvon FES,
so that as things have not worked.
Also, your problem is these symptoms.
So I think that you've got a cracked version.
Download the new version are fixed shut and your problems.
If your v2.6.1 license is legitimate, just download v3.3 and install it over the top.gerryd wrote:I have a valid copy of 2.6.1, maybe I should just buy 3.3, anyone know what it costs more or less?
The activation will be carried through to the new version - it's a free update.
