Page 206 of 257
Posted: 17 Jul 2016, 10:15
by geniusmiki
Hi BlastUM do you have solved? i'm in your same situation.
thanks
Posted: 17 Jul 2016, 21:47
by BlastUM
geniusmiki wrote:Hi BlastUM do you have solved? i'm in your same situation.
thanks
no, I haven't managed to make it work
Posted: 25 Jul 2016, 09:21
by rafe005
Hi all, got the same problem here with my elm cable and paid version of multiscan, it won't connect to the airbag ecu on an Alfa 159. It's different to the other circuit boards I could see on this thread that have had an answer (re removing resistor etc) so could someone point me in the right direction as to the modification of this board please, it's the same one as this guy has.
Thank you
inotalas wrote:Hi all, first of all congratulations to this community, there's a lot of very useful information.
I'm writing here because I bought an ELM 327 adaptor and I can't connect to a Fiat Marea JTD 105 '01 ECU. The test on MES are correct and the interface returns every command with OK but it can't connect to ECU.
Looking the first post I see that my interface have another PCB design and I don't know where to start to solve the problem. If someone can help me, see pictures attached below.
Thanks in advance.
Posted: 26 Jul 2016, 13:41
by slaine_mcroth
Hi all,
I'm currently facing a steering issue on a punto Mk2 1,3 multijet, i cannot access to steering modul (engine modul works fine, using multiecuscan)
Hereafter pictures of the OBD cable i'm using, seems close to betyargabor (page 36) and fiatbravoemotion (page 38)
it's 2012-02-06 b1uwOBD V1.6
can you confirm that if i remove R04 i will be able to read ABS and steering modul ?
THX
Posted: 26 Jul 2016, 14:19
by slaine_mcroth
I answer to myself
Yes it works
slaine_mcroth wrote:Hi all,
THX
Posted: 26 Jul 2016, 18:41
This has already been described many times here
In order to read the steering on the Alfa 159 has to be removed this bridge resistance.
If, yes, if the ELM is compatible with MES.
To read the ABS on Alfa 159, the resistor has no function
equals Whether inside or removed
For the ABS the green adapter.
Posted: 28 Jul 2016, 13:25
by Lezli46
Absolult sorry...,I wanted to do the modifications , bat ther is no such low capacitor 560pF with polarizeid "packings"!!! other value can not be replaced ??
regadse
Posted: 28 Jul 2016, 13:59
by eVinicius
Hello everybody!
What resistor should remove ?!
Thanks!
Posted: 29 Jul 2016, 21:02
by ciocclaude
Lezli46 wrote:Hi
regadse
Did you take a look at my response to your post of July 10 in the "General" section?
I think you should.
C.
Posted: 29 Jul 2016, 21:14
by ciocclaude
eVinicius wrote:Hello everybody!
Thanks!
What car do you have, what kind of problem(s) are you experiencing, can you connect to the engine ECU?
The resistor in question is clearly visible in the 2nd picture in your post right above pins 6 and 7 of the MCP2551 (it looks like 120 ohms). Follow the procedure detailed in one of my previous posts. Remember that removing this resistor is worthless if your interface does not connect as it is to the Engine ECU.
Take care
C.
