Multiecuscan Full package.
Re: Multiecuscan Full package.
MES 1.5 (the version in your linked picture) is a very old version of MES and the format of the Errors page/tab has changed a little. However if you go into test mode with the current version of MES and select the Ducato 2.8 JTD (244) and go to the Errors tab YOU WIILL SEE EXACLTY what you are looking for.
The codes you see/seek are PRE EOBD codes and very much manufacturer specific codes.
You don't say what vehicle you are testing but I strongly suspect it is a later model where the more universal EOBD code formats are used.
Timmy
Post by Timmy »
Appreciate your help and guidance. As always you are correct, I,m trying to diagnose
an ABS wheel sensor open circuit issue on a 2006 Doblo.
I think the fog is starting to clear a little thanks to your input.
Regards
Tim
Tuner182
Post by Tuner182 »
Hello I have the problem with proxi in my 159 (2009). I changed my radio to Radionav. My 159 had uncompatible instrument cluster and body computer with new Radionav. I have already changed what was needed (new body computer and instrument cluster). My car is fully compatible with RadioNav at this moment. Everything works perfect. But I have still problem with proxi. Odometer don´t flash and everything seems to be correct. Report from can info is also correct. The problem is when I want to connect to Radionav. I am able to connect with MES but the connection is not correct. In window "Info" there is nothing no HW/SW information only blank window. I tried to connect with Alfa OBD but nothning alfa OBD shows info that "unit did not answer the connection will be canceled"
CAN CONFIGURATION DATA:
05 B6 97 FB 05 B6 97 FB 04 20 00 62 00 00 00 00 00 00 00 00
05 B6 97 FB 00 22 05 A9 05 B6 97 FB 00 22 05 A9 00 22 05 A9
32 31 31 34 30 30 32 32 36 39 32 4F 55 54 50 55 54 2D 4A 49 54 20 09 04 21 FB 97 B6 05 A9 05 22 00 E3 6D 24 07 B7 80 14 17 01 0F 9C 06 01 00 01 06 00 00 00 32 50 97 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 42 40 B1 88 02
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Info-Telematic/Convergence Node (NIT/NCV)
Driver Door Node (NPG)
Boot Node (NVB)
Climate Control Node (NCL)
Steering Angle Sensor Node (NAS)
Side Acceler./Yaw Node (NYL)
Passenger Door Node (NPP)
Driver Seat Node (NAG)
Teg Reader Node (NTR)
Steering Lock Node (NBS)
Passenger Seat Node (NAP)
Parking Sensor Node (NSP)
Airbag Node (NAB)
CONNECTED TO:
Alfa Romeo 159 2.0 JTDm 16V
Body Computer Node (NBC): EOL Ok
Engine Control Node (NCM): Ok
Dashboard Node (NQS): EOL Ok
Steering Wheel Controls Node (NVO): Ok
Receiver Radio/Radio Navigator Node (NRR/RMN): EOL Ok
Brake System Node (NFR): Ok
Info-Telematic/Convergence Node (NIT/NCV): EOL Ok
Driver Door Node (NPG): EOL Ok
Boot Node (NVB): Ok
Climate Control Node (NCL): EOL Ok
Steering Angle Sensor Node (NAS): Ok
Side Acceler./Yaw Node (NYL): Ok
Passenger Door Node (NPP): EOL Ok
Driver Seat Node (NAG): Ok
Teg Reader Node (NTR): Ok
Steering Lock Node (NBS): EOL Ok
Passenger Seat Node (NAP): Ok
Parking Sensor Node (NSP): Ok
Airbag Node (NAB): Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN) FAILED! - Timeout error
Writing to module: Info-Telematic/Convergence Node (NIT/NCV) SUCCESS!
Writing to module: Driver Door Node (NPG) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
Writing to module: Passenger Door Node (NPP) SUCCESS!
Writing to module: Steering Lock Node (NBS) SUCCESS!
FAILED TO EXECUTE
Any ideas?
Timmy
Post by Timmy »
I think you might get more results for your issue if you start your own specific
thread instead of your query getting lost in my one.
Good luck anyway.
