Retrocamera 500L e 500x
alex-et3
Re: Retrocamera 500L e 500x
Post by alex-et3 »
LWN500X wrote:I thank you, very kind, but too many things to do. :o :o :o :o :o
If you purchase a model: FIAT 334 VP2 ECE DAB RVC no NAV?
Thank you.
Loris :roll: :!:
Yes,ok.
But,buy it with the dab only if your car currently has it.
However,to run the Live services will have to do in fiat workshop the writing process of the frame number in the uconnect unit.
LWN500X
Post by LWN500X »
Thanks. ;)
alex-et3
Post by alex-et3 »
LWN500X wrote:Thanks. ;)
Is it not cheaper to mount a special interface than to change Uconnect?
LWN500X
Post by LWN500X »
I have seen more interfaces but it is specified that they only work if my car radio is set up with RVC hardware. I have a FIAT 334 VP2 ECE without RVC hardware.
Do you have a better solution? :idea:
Loris :cry:
alex-et3
Post by alex-et3 »
LWN500X
Post by LWN500X »
I thank you but too expensive, € 399.00 or € 649.00. :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
I leave my rearview mirror with 4.3 " :D :D
Thanks.
Loris ;)
alex-et3
Post by alex-et3 »
LWN500X wrote:I thank you but too expensive, € 399.00 or € 649.00. :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Thanks.
Loris ;)
Yes, they cost a lot of those interfaces, but I do not know if there are alternatives.
stalky911
Post by stalky911 »
Ive the
Pn: 735605097 AUTORADIO 6Q2 + !316
Will it work with this uconnect? And also i would like to know how to enable the parking sensors and install them as well.
alex-et3
Post by alex-et3 »
stalky911 wrote:Ive the
With this uconnect you can not mount the rear view camera.
