Multiecuscan 2.0 - WORK IN PROGRESS!!!
albertodg2
Re: Multiecuscan 2.0 - WORK IN PROGRESS!!!
Hi:
I need the support of the Bosch Motronic ME796 for Palio 1.2 16v
Pustynnikov
For anyone asked, but no answer: Can you please tell how much estimated will cost commercial version of the excellent programs Multiecuscan in version 2.0?
Expecting the support of the old ECU, such as Bosch Monojetronic & Etc?
And, if you need some help with translation into Russian language - I'm ready to help.
Is the elmscan5 kabel from scantools.net suitable for this? as it is a cheap cable...yani wrote:"Service Reset" for Fiat Stilo will be available in the new version.
You will need ELM327 v1.3 or newer.
I'm not 100% sure because I don't have it, but according to the info on internet it has EML 327 v1.3a inside. So, it should work.Entonox wrote:Is the elmscan5 kabel from scantools.net suitable for this? as it is a cheap cable...
what kind of cable do you advise to use? (Brand/Type)
Hi yani,
can´t await the new version with ELM 327 support. Currently I am using USB version of ELMScanmaster OEM (WG-Soft) with a USB ELMCanII adapter cable. Will that cable be supported as well?
BR,
Frank
BR,
Frank
I think it will be supported! Did you bought you interface on web page www.obd-2.de?fs1958 wrote:Hi yani,
BR,
Frank
According to web page www.obd-2.de your USB ELMcanII adapter cable is ELM 327 1.3a version and yani in previous message wrote that for multiecuscan version 2.0 will be needed ELM 327 inteface v1.3 or newer.
... so it should work! Great!
Hari-Alfa
- Location: Hangery Bekes megye Újkígyós Petőfi S.utca 50 sz 5661
Hi Yani!
I would like to ask, what's the problem? Today I tried to Alfa156 Selespeed '00, and the engines are not connected!
- The airbag OK!
Then I tried 147 1.6 103LE ('05) and managed everything perfectly!
What could be the problem?
- The airbag OK!
I try the last version and you software is very interesting.
I need the correction about DPF regeneration.
If it possible in next version 1,6 mjt or t-jet of Alfa Mito
Good job !
Good job !
