Automatic Climate Control aftermarket on Fiat Stilo
Re: Automatic Climate Control aftermarket on Fiat Stilo
Ok, the problem with Stilo NCL PROXI alignment will be fixed soon in Multiecuscan 3.4.2.
@gioz already tested it on his car with his ELM interface and it works fine now.
Pavel
Post by Pavel »
Great, it works already, KM not blink. Thank you. They diagnose the glass roof, he got stuck and can not open a combo box is stuck in the very back?
nicolt
Post by nicolt »
despite updating 3.42 continuous not to work alignment proxy ncl reached the automatic climate it fails and it doesn't complete. does the whole rest work you have some idea?
nicolt wrote:despite updating 3.42 continuous not to work alignment proxy ncl reached the automatic climate it fails and it doesn't complete. does the whole rest work you have some idea?
Go to serial port driver settings and set "latency" to minimum. Or try with different drivers.
I saw some reports from failed Stilo NCL PROXI Alignment where the latency was >20ms (and that's too high for Stilo NCL).
nicolt
Post by nicolt »
The problem was the latency. all now works perfectly.
thanks Yani
silgal191
Post by silgal191 »
But to stilo 1.8 16v 2002 the problem persist. I change the latency to 1 But the same error.
