can't connect to airbag via pin3
Allan
Re: can't connect to airbag via pin3
Post by Allan »
Hi Again.
Went by a great Alfa shop at Amager near Copenhagen (Car Center) they read the fault, reset the light and printed a report for my in less than 5 minutes. Problem is periodical fail on the drivers seat-belt tightener. And they didn't even charge my PERFECT. Car Center at Amager THANK YOU.
By the way I also hare tried AlfaDIAG without any luck.
Kalle here is a picture of the location of the "fucker" as it's called from here on and after ;)
Best /Allan
CAR CENTER thanx.
kv99
Post by kv99 »
palamp wrote:This fuck airbag system all with the Nr 707 Regards
do you meant the serial number, or what number are you refering to ? I'd like to check if I have one of those.
palamp wrote:Solution update to a new ecu system from 2003. Regards
not really a soloution though, at least a pretty expensive one
But a Fiat shop can reset that ECU, right ?
kv99
Post by kv99 »
Allan wrote: And they didn't even charge my PERFECT. Car Center at Amager THANK YOU.
What a great Dealer !!!! My cash-hungry dealer charges 30 Euros for the reset !!!
Allan wrote:Kalle here is a picture of the location of the "fucker" as it's called from here on and after ;) .
I support you by calling it "fucker" ALSO from her on and after !!! :mrgreen:
soldiiier
Post by soldiiier »
Alfaeddy wrote:Hi
What kind of vehicle you want to read?
For example the when Alfa 159 is the airbag by CANBus read and not via
Pin 3
Which adapter is to be used for this airbag on 159 Eddie?
Thanks.
soldiiier wrote:
Alfaeddy wrote:Hi
Pin 3
Thanks.
For the Alfa 159 no adapter is needed.
Because when the airbag 159 is read via CAN bus.
So with the KKL interface is not
Only with an ELM or OBDkey is possible to read
soldiiier
Post by soldiiier »
thanks for the reply eddie. i think the problem is with my interface and the bridging resistor...
although i purchased v1.5 ELM to prevent this, they are still having issues??
thanks
update, before undoing ym interface, i want to confirm,
i have checked the resistance between pin 6 and 14, and i get a reading of 1.01 k Ohm
is this good enough?
it is a much higher resistance then the 120 Ohm that was on some of the interfaces
The resistance of ~ 1 kOhm is ok
Can you connect to the engine ECU or ABS?
this is read via another protocol
or
you can connect to the CAN setup, Body Comp. ; Air et al produce?
I think first time to your settings.
