Re: new relase 2.8
Posted: 03 May 2011, 09:02
Naturally Yani that I tried everything with everything already ...
All items SLOW, OPTIMAL, FAST & DEFAULT
Same with different com port settings that are possible .... many different settings as I tried to think nobody did
and nothing, allways it' this same problem
I talked with a friend who is a professional laptop and netbook servis, and said that just some of the laptop may have internal constraints operating the program despite the fact that for example the processor is better than the manufacturer recommends the program - just life
simple buy new laptop
Thank you YANI for your interest in our problem. Generally, mine is the smallest, because if I' want this connection to the engine ECU and will read anything by using ELM 327th If I' want to connect to the ABS ECU & AIRBAG'll do it and it works whit VAG KKL
One would have to help a colleague as wombi above, Alfa Eddy etc
