Hi guys,
It's my first post here so hi to you all!
I just wanted to ask your advice. I want to connect to my Barchetta 95' ECU (not airbag, not ABS). Frankly, after reading all this I found that it no longer know which connect is which. I have a 3 pin connector/plug under each seat that run to the seat belts tensioners. I assume these I can use to connect to airbag controller.
Apart from this I have not found any other plugs in the foot wells or elsewhere in the cabin, well, maybe there is something near the blower but did not have a closer look.
Now, under the hood, I have found a 3 pin connector near ABS pump that I tried connecting with my laptop (Win 7) and with VAG KKL cable (with dip switch with positions 7 (KKL), 3 (airbag), 1/9 and some one more don't remember exactly for). The dip switch is set on 7 then I have the 16 to 3 pin adapter to connect to it. The interface is recognized as FT232R USB and v2.08.28 drivers are installed. I can only perform "scan" which recognizes this port as ABS controller (not recognizable though).
Here's where is it located under the hood:
So, I went looking for ECU port and found this near the relays under the ECUs plastic cover:
I suspect this is the one, but it's different type of plug: 4 pins instead of 3 pins. One pin is not wired but the adapter does not work obviously.
Did any of you was able to determine if this is the right plug? If it is, how is that it's 4 pins not 3 like everyone else mention in the internet?
Regards,
Michal
