add ecu iaw 6/8/16/18 F
Re: add ecu iaw 6/8/16/18 F
Hallo, i ask at a seller, if i can make motor diagnostic control on fiat brava 1.6 16v (1997) fiat cinquecento (1997) and lancia delta gt 1.6, hf, integrale, ecc. he said ies for delta and brava, and if i have fortune cinquecento too. i have buyed FES, but i can't use whit brava and cinquecento,
IAW-1AF.16/5524-AA (marea bravo/a 1.6 16V)
IAW- 16F .ER/2A30-A8 (500 1.1 ECE FASE2)
The selles don't know the car and the elecronic, or he pretends.
I think that the seller don't won't assist buyer after buying, and this is not good for fiaecuscan immage!!!!!!!!!!!!!!!!!!!!!
However, AS i can do for use FES,elm327 or usbkkl, 3wire adapter to make the diagnosis on IAW-1AF.16/5524-AA (marea bravo/a 1.6 16V)
Thank you for patience and bad english
FES has no support for IAW-16F nor IAW-1AF. However you may use your interface together with FIAT 3-pin adapter for diagnosing IAW-16F using IAW-Scan2:
http://sourceforge.net/projects/iaw-scan2/
IAW 1af is supported in IAW-Scan2 ??? Or only IAW-16F ??
No, IAW-1AF is not supported, only IAW-6F, 8F, 16F, 18F, 18FD and 4K.P8 are supported in IAW Scan 2.
i am dissapointed with the fact that one of the most used ECU's in Fiat older cars still isnt added in multiecuscan...
it doesnt make sense to me that the ABS and the Airbag were able to be added but the Engine IAW 1F wasnt...what is the problem?
in my country there are few hundreds (maybe even more) Fiat cars with this ECU, i personaly have Bravo and Brava with this ECU
also the IAW 4WF is missing from the begining of the multiecuscan...this is the ECU of the Fiat Coupe 2.0 16v turbo...however the 2.0 20v turbo has engine ECU...
is there any way to add this ECU-s in the FES or is there any program except Visa uniscan that can work this ECU-s?
Hello Yani, are increasingly enthusiastic mind continues to update the program, but I wanted to ask why the new multiecuscan 1.0 do not support the old unit for five hundred old - panda - point, the IAW 6f - 8f - 16f - as well as the spear y IAW with 16f - I hope to reply soon
regards
96 Aron
regards
96 Aron
did you tried to use this soft: http://iaw-scan2.sourceforge.net/?Aron96 wrote:Hello Yani, are increasingly enthusiastic mind continues to update the program, but I wanted to ask why the new multiecuscan 1.0 do not support the old unit for five hundred old - panda - point, the IAW 6f - 8f - 16f - as well as the spear y IAW with 16f - I hope to reply soon
regards
96 Aron
it should work with IAW 6f - 8f - 16f ...
Hello Alfa156sarajevo, I have not tried this software, my request and simply to be seen to complete the multiecuscan which changed its name to as a means to enlarge the software, then I use a generic program, so I have no problems, I however iaw2 tried to download but the download seems too small 25kb program I tried even then. But returning to my request if we see the demand for this diagnosis for old cars and very many who would buy the software and this request does not seem to be so wrong in the program the chance to grow even more if I'm then saying something wrong tell me, I have translated from Italian with google if there is something that you do not understand the translation, sorry.
ciao aron96
ciao aron96
I have no idea what have you downloaded, here's the valid link for IAW Scan 2:
http://sourceforge.net/projects/iaw-sca ... t/download
The file size is 392kB, program supports generic communication with IAW 4K/6F/8F/16F/18F/18FD ECUs, so old Pandas as well as Coupe 2.0 16V Turbo are supported.
Hello guys
I used tzok softwear in Fiat Punto Selecta and it worked like a charm
I cannot say same for my expencive FiCOM which said that it has supposert for this kind of ECU's but it dosen't
I don't want to say that my very expencive FiCOM cannot do the ProxyAligniament as FES or MultiEcuscan can do it.
MultiECuScan - 49 Euros - Tzok IAWSCAN2 - 0 Euro - FiCOM 469 USD ( including shipping cost )
Good job tzok adn we still wait the old cars ECUS coverage in the MultiEcuScan
