Page 195 of 257
Posted: 16 Nov 2015, 03:59
by cxem
bozza,
BK3231Q + MCP2515 + TJA1040 = This is bad
ELM-327(PIC18F2480) = Ok
ELM-327(STM8) "VGATE ICAR2" = Ok
http://forum.cxem.net/index.php?showtopic=144556
Posted: 16 Nov 2015, 21:05
by bozza
cxem wrote:bozza,
txh
Posted: 20 Nov 2015, 13:21
by aparty
Alfaeddy wrote:
aparty wrote:
Alfaeddy wrote:Hello Aparty
Your interface is the same as the ELM of Tamso
Therefore you need to remove the same resistor (121) to
to make your interface CAN bus capable of MES,
Thanks Eddy for your support.
I'm going on to remove that resistor.
I'll update as soon as possibile.
One info: after removing that resistor, ELM327 will work with other software or it will work with MES only?
Thanks!
Hello Aparty
Yes
Up to the version v1.3 ELM Interface
was not built this bridge resistor.
And this interface could also use other software.
Just to say you I removed the resistor, but I had the same problem: I can comunicate to Engine ECU only!
Why?
Aparty
Posted: 30 Nov 2015, 13:55
by tony088
Hi,i have a problem with multiecuscan and elm327 v1.5 usb. I want to connect to ECU of alfa 147 1.6 105 cv,but i receive this error:connection failed,timeout operation. Check the settings of the com port, pin EOBD adequate.I tried to change the speed but I have not solved. Elm327 has chipset ch340 . This is test interface connection:
Command: ATZ
Response: ELM327 V1.5 >
Command: ATI
Response: elm327 v1.5>
Command: ATE0
Response: ATE0OK>
Commando: ATL0
Response: OK>
Command : ATH0
Response: OK>
Command: ATSPC
Timeout operation
Posted: 30 Nov 2015, 14:23
by ziopalm
Hi.. same problem with alfa 159... someone can help us?
Posted: 30 Nov 2015, 23:00
Thanks!
Hello Aparty
Yes
Greeting Eddy[/quote]
Why?
Aparty[/quote]
Do please have a picture of the board
and again a screen from Interface Test
Posted: 04 Dec 2015, 18:56
by btibor76
Argo wrote:I found a quick and dirty solution:
  • Bought the cheapest ELM327 interface from eBay (actually V1.4)
  • Disassembled and found I had the board below.
  • Using a craft knife I carefully destroyed the 120ohm resistor (R04 on the board). Be careful you don't damage R17 just beneath it.
  • Resembled and it works a treat!
hang around for everyone especially those who invented this forum had I applied to give up hope that I will ever be able to do has been tried everything to me Fiat Bravo 1.9 Multijet 8v is and has been to you thanks to say the clima control we do not know yet achieved any anyone has idea ?? ?
Posted: 05 Dec 2015, 14:45
by ragezor
Hello, I've bought this ELM intarface. It is v1.5
http://www.aliexpress.com/item/Auto-Dia ... 86486.html
I've tried it on two cars: honda accord 2005 and nissan juke 2015. It does not work on both of them.
[obd] ========================== python-OBD (v0.4.0) ==========================
[obd] Explicit port defined
[obd] Opening serial port '/dev/rfcomm0'
[obd] Serial port successfully opened on /dev/rfcomm0
[obd] write: 'ATZ\r\n'
[obd] wait: 1 seconds
[obd] read: 'ATZ\r\r\rELM327 v2.1\r\r'
[obd] write: 'ATE0\r\n'
[obd] read: 'ATE0\rOK\r\r'
[obd] write: 'ATH1\r\n'
[obd] read: 'OK\r\r'
[obd] write: 'ATL0\r\n'
[obd] write: 'ATSPA8\r\n'
[obd] write: '0100\r\n'
[obd] read: 'SEARCHING...\rUNABLE TO CONNECT\r\r'
[obd] write: 'ATDPN\r\n'
[obd] read: '0\r\r'
[obd] Connection Error:
[obd]     ELM responded with unknown protocol
[obd] Failed to connect
This is python obd library communicating with the ELM interface. It seems that connection to the computer works just fine, but connection to the car does not. Has anyone discovered how to repair this interface maybe? I can provide pictures of the board if needed.
Posted: 05 Dec 2015, 14:58
by ragezor
Posted: 06 Dec 2015, 14:34
by cxem
ragezor. Hello.
You have an adapter on a new chip STM32(U5)
What CAN-driver(chip U2)?
What is the USB-driver?
Bad, there is no stabilizer +5v(chip U1)
Thank you for pictures
I need to pictures mainboard(CY-B09_ST)
