Delce
Post by Delce »
Hello Alfaeddy! Ok, I'll try take some screens of the test later.
Where can I find a cable that work good and the vendor send to Spain? I can buy in aliexpress or other site. Maybe the cable that I bought isn't compatible with FES...
Thanks for help me!!
Delce
Post by Delce »
Hello, here I insert 2 screens.
http://i.imgur.com/wXNZkfb.jpg
http://i.imgur.com/6WdDtns.jpg
With MES the result is the same...
http://i.imgur.com/WnDQbxE.jpg
Hello Delce
Unfortunately, it looks like this, which is not compatible with your ELM MES Interface.
Your test queries are not answered within the time limit, and therefore is the
aborted test
You should buy a compatible ELM
Delce
Post by Delce »
Alfaeddy wrote:Hello Delce
aborted test
Ok, thank you very much! Where could I buy a compatible ELM that send it to Spain? In Aliexpress vendors send to a lot of countries, can anybody show me one?
M0ises
Post by M0ises »
Hi, i was trying to connect with an v1.5 elm 327, so i doesn´t works neither as v2.1? Am I right?
V1.4 works?
The built interface are too different
even under the v1.5 ELMs there are those that are not compatible with MES.
Make a test with MES Interface and you can see whether your ELM works
Not all v1.4 ELM works
M0ises
Post by M0ises »
So, I must use v1.3 to be sure that it works. :(
RSA1976
Post by RSA1976 »
Halo, guys.
I founded this kind of device:
http://s017.radikal.ru/i403/1510/92/6d1fa2d247fft.jpg
http://s019.radikal.ru/i602/1510/cc/ee5f04ef6c8dt.jpg
Its mainboard is v.1.2a but SW on corps has v.1.4. I saw any posts with this kind of ELM327 at the begining of this topic. All of them has only questions but not any answers about resistance to unsolder or how to remake device to make it work with FIAT CAN-bus. I confused to do anything with my ELM327. R4, R2, R04, R... Can somebody please help me with the right decision? Thank a lot in advance. Last info: in Multiecuscan all tests are OK and "Compatible 1.4". There is not any FIAT near me for the moment to check my device.
rossi00069
Post by rossi00069 »
Can anybody help me to find the bridge resistor?
Can connect to the engine but not to any other options.
Alfa 159 2011 2.0 Diesel
I cannot upload any pictures "Sorry, the board attachment quota has been reached."
But I have the V3.0:
http://www.aliexpress.com/item/elm-327- ... 77052.html
Without that you can adjust an image here you not with your ELM help
But now probably 90% of all interface are illustrated here
You just have to seek out your
