VAG KKL cable connections
DanilViacy
Post by DanilViacy »
A word of personal experience: be wary of the entirely blue KKL cables. I got mine in the mail today, and the USB connector was some bootleg shit, and the contacts were recessed way too much into the phelonic white spacer thing, and one of the pins had broken in the connector. I had to do a transplant and solder in a new USB cable to the OBD side to make it work.
Stingy1075
Re: VAG KKL cable connections
Post by Stingy1075 »
Hello everyone, i bought the interface in the pic below. When i try to connect, it doesn't work. MultiECUscan recognize it, but it doesn't connect really or show any codes when i do a diagnostic. If i try the "Connect" feat on the software, it says that i need ELM37/OBDkey to connect...
P.S., my car is a Punto Abarth from 2009.
Your problem is that this is the wrong interface.
All Punto post 2003 (03) use the CANBus network and protocols and not the VAG KKL.
See: https://www.multiecuscan.net/SupportedVehiclesList.aspx
Stingy1075
s130 wrote: 30 Jun 2023, 11:56 Your problem is that this is the wrong interface.
Thanks, i see now. i returned this one and i bought a ELM and the yellow cable.
Ernygr.exy_
Post by Ernygr.exy_ »
Can anyone help me decide Can hi,Can lo,Bus+,Bus,K-Line,L-Line,GND,+12V
Photo https://drive.google.com/drive/folders/19gv7IUNbBZVHQ6uKbH4SfxZsKmuu78jq
