What did you tried to connect, I mean what controler?
Airbag?
Airbag?
After your test should work to connect?
If a control found when you scan (F11) press?
eric.dervel
I try to connect engine. The 3pin for the engine i think it is on the right (passenger) side near the shock absorber.
When i press SCAN:
Scanning ...
ELM 327 Bluetooth interface found at port COM6, speed 38400bps
COMPLETED
When i press CONNECT:
CONNECTION FAILED You need K-Line/VagCom/OBDKey interface to connect to this module! Check your cable and serial port settings!
When i press SCAN:
Scanning ...
COMPLETED
Hy it is not your tool fault.
Take a look here
You'll see that if you have a car with 3 pin adaptor you'll need always VAg kkl for that controlers.
And if I understand well you car enginese it is not covered yet.
BTW your ELM327 it is unusefull for your car because no CAN in it.
Take a look here
Added photos.dapo wrote:Hi. I need to connect to all services but i have this problem. I have a 159 1.9 JTDm:Code: Select all
COMMAND: ATZ RESPONSE: ATZ ELM327 v1.4 > COMMAND: ATI RESPONSE: ATI ELM327 v1.4 > COMMAND: ATE0 RESPONSE: ATE0 OK > COMMAND: ATL0 RESPONSE: OK > COMMAND: ATH0 RESPONSE: OK > COMMAND: ATSPC RESPONSE: OK > COMMAND: ATS0 RESPONSE: OK > COMMAND: ATCAF0 RESPONSE: OK > COMMAND: ATCFC0 RESPONSE: OK > COMMAND: ATCRA 7B0 RESPONSE: OK > COMMAND: ATSH 7B0 RESPONSE: OK > COMMAND: ATAT1 RESPONSE: OK > COMMAND: ATST41 RESPONSE: OK > COMMAND: ATBI RESPONSE: CAN ERROR > WARNING: This interface is not compatible with ELM 327 1.3! Will not connect to any CAN module.
Can anyone helpme ?
eric.dervel
Thanks guys!!!
...and finaly..my adapter is working..sorry if i was borring with my noob questions, but things getting clear in my mind now, so i will help someone in future.
Now its working on my Bravo 08'', but i can read only few things...(i need that 3 adapter cables A1,A2,A3)?? (in my case A1)
Now i want to buy KKL Vag Com for my older love Bravo 2.0 20v 97''.
Will this one work://www.ebay.com/itm/USB-VAG-COM-OBD-II-KKL ... 239wt_1270
or i must buy this one:
http://www.ebay.com/itm/Multiecuscan-FI ... 526wt_1270
So was your fault, no fault
I thought that with the adapter cable would be often enough described.
Both KKL interface will only work you need for the black KKL these adapter cables
And for the blue one with the slide switch, the cables are not needed.
I was struggling to connect to car airbag.
After reading this post I bought one of these kits off ebay and it worked first time:
"ALFA FIAT DIAGNOSTIC LEAD CABLE multiecuscan + ELM 327 v1.4 + KKL VAG COM ODB2"
I was surprised as I could connect to every ecu using different combinations within the kit.
Ebay user, "buy_me_from_dan", seems to know what he/she is talking about, and has many different combinations listed.
Thanks for all the help and advise posted on this listing.
Ted
Ted
Hi I found this kit but I have a question.lollipop wrote:I was struggling to connect to car airbag.
Ted
An administrator has tried this kit?
Can write a review please?
Hi All !!!
Sorry for my bad english, i'm italian boy!
i'have one problem,
My interface is obdpro usb scantool.
With the program OBD2007 lite works perfectly but the diagnosis with fiat ecu scan out the error can module
Why???
With Fiat Ecu Scan
Interface
i'have one problem,
Why???
With Fiat Ecu Scan
Interface
