Page 19 of 256
Posted: 12 Nov 2011, 15:47
Hello Eric
Your BT interface described here does not have this resistor (R04, R14)
It should kidney function, I suppose you've got a hiring mistake
Check your settings again then it should work.
Posted: 12 Nov 2011, 19:57
by dapo
Hi. I need to connect to all services but i have this problem. I have a 159 1.9 JTDm:
RESPONSE: ATZ
ELM327 v1.4
ELM327 v1.4
RESPONSE: CAN ERROR
Can anyone helpme ?
Posted: 12 Nov 2011, 20:10
by eric.dervel
Thanks for very fast reply!!
My bluetooth OBD works with my bravo 08'' with ,,Torque'' android, but with FES i have another unsuccessful try.....The pc never ask for drivers, but i instal CDM drivers, I set the correct com port (in my case COM6) and when i go to settings-interfaces-TEST it say ''Access to the port 'COM6' is denied''. And for the resistors i have R14, but i don't have R04, maybe R4 is the same as R04?? I am such an amateur with this tools, sorry if my questions are so noobish...and THANKS again.
Posted: 12 Nov 2011, 20:12
Hello dapo
Which interface do you have?
Is there a Bluetooth version?
Show times a link to which interface it is.
Posted: 12 Nov 2011, 20:25
Hello eric
It depends on where the resistor R04 is installed.
This resistor must be removed only if this on the MCP2551
Contacts 7 + 8 connects
Otherwise nothing is changed.
I can here not, of course, when you determine which setting is not right
Posted: 13 Nov 2011, 00:43
by eric.dervel
Thank you Alfaeddy,
To be honest i don't understand your last post, because i don't have expirience with this thing.. Can you please tell me more details about what to do now and how to detect what i need to remove, to make it work?? Thanks and sorry if i borring to you.
Posted: 13 Nov 2011, 11:43
Sorry for my bad English
After your board from the interface, I can not detect and remove the one you have to resolder or resistance
It must work even without conversion.
Go through these steps
- Your Bluetooth interface is detected?
- Which Com port?
- Set this com port in FES / settings / interfaces.
- Set the correct interface
- In the Control Panel for this com port the latency set to 1
- Press in the FES / Settings / Interface / the test!
- Adjust this test result here.
Posted: 13 Nov 2011, 14:51
by eric.dervel
Helllo,
Everything is set as you say, just can't find option in com port settings for latency to set to 1.
Posted: 13 Nov 2011, 15:38
by mattydr67
Mates just for VAG KKL you need to set latency to 1
For ELM327 you don't need to do this
It has to remain default ( latency 16 )
Posted: 13 Nov 2011, 17:12
by eric.dervel
Thanks guys for all replies, it help me a lot!!!
Now i have some good news!! Because i have instaled ScanToolNet, it uses COM6 and because of that i always got message ,,com port acess denied,, Now that is ok. I get this message:
RESPONSE: ATZ
ELM327 v1.4
ELM327 v1.4
When i go to FES in settings-interfaces-scan for interfaces it say:
Scanning ...
ELM 327 Bluetooth interface found at port COM6, speed 38400bps
COMPLETED
I try to connect with Fiat Bravo 97'' 2.0 20V, but it shows with red colour text and say: CONNECTION FAILED You need K-Line/VagCom/OBDKey Interface to conncect to this module! Check your cable and serial port settings! My port is set on 38400 Bits(also try with 9600 but the same). I dont know what is wrong now. Thanks
