lucarossi.1963
Post by lucarossi.1963 »
Alfaeddy wrote:Hello Lucarossi
What ELM this is because in the image
v1.5?
or
v2.1?
This is the version v2.1 not to change to work with MES can
But the v1.5 before, this is to be modified.
But I do need a better picture
and yet
What kind of car and what control you want to read ???
I was sold for elm327 bluetooth V1.5 but when I run the test from the list to me by v2.1
I would like to perform diagnostics for engine fiat punto 1.3mjt 2009.
What are you going to change it?
I removed the resistance 27 and torque I read the engine control unit, I also raised the resistance R4 hope I have not compromised the intrfaccia.
The outcome of the test and always equal .........
I am attaching below
  • COMMAND: ATZ
    RESPONSE: ATZ
    ELM327 v2.1
    ELM327 v2.1
    RESPONSE: ?
    RESPONSE: ?
    RESPONSE: ?
I do not understand why you have the resistor R4 away ??
And the resistor R27 has probably unrelated to the bridge. !!
What ohm reading is R27 ??
Please remove even the white plastic on the 4 pins
possibly the resistor is below
lucarossi.1963
Hello Alfaeddy
the R27 was about 100 ohms between pin 6:14, sorry I do not understand what I have to raise more. I'm Italian and I'm using a trans latore
Hi Luca Rossi
I also use a translator to
The resistor must have 120 ohms when R27 = 100 ohms he is not.
At the 8 plug pins you can remove the white plastic base
Look after including whether are still resistors.
lucarossi.1963
Hi Alfaeddy
resistance R27 measurement scale 200 ohms = 98.2 .....
What should I lift near the white plug 8 pin?
one marked with a red circle?
lucarossi.1963
Anyway, I wanted to know if you can change the firmware since multiecuscan recognizes him as elm 327 V2.1 and says it is not compatible with elm 327V1.3 (and will not connect to any Canon .......... .)
Hi Luca Rossi
No, I mean, look under the white housing
I once marked the approximate locations.
This white housing can be removed upwards.
IMG_4368 markiert.jpg (66.2 KiB) Viewed 10146 times
Post by Waltomatic »
WOW, big job!
lucarossi.1963
Hi Alfaeddy
here he is now?
pumpingiron91
ELM327 Problems......
Post by pumpingiron91 »
Hello everybody, I bought a super chinese ELM327 v1.4 cable but it reads only the Engine Control Unit (Multieciscan, registered). I know, I have to change some resistance or capacitor, but this type I have not found it yet. I add a picture about mine.
!!!Thanks your help!!
