tasmo
Post by tasmo »
i have TJA 1040 chip
Hello Tasmo
Remove the Resistor in the red Frame
and you can read the CAN Bus Protokoll
of your Car
IMG_0591 markiert.jpg (806.35 KiB) Viewed 7510 times
tasmo
Post by tasmo »
Thanks Eddy,i removed resistor and now it work, only electric servo ecu cant connect(not found).it look like its problem with servo ecu because servo not working
dodo
Post by dodo »
there is no other data on this interface.
Alfaeddy wrote:Hello Dodo
I do not know this interface
Do you have data on this interface ???
Which operating system do you have on your laptop ??
Which driver do you use ??
And the motor controller and the ABS of your Alfa 159 have no CAN bus
So should connect to these two controllers + ECU (ABS = Adapter1)
without changing the board be possible.
dodo wrote:Hi,
Or a link from the seller?
MF07
Post by MF07 »
Hi Guys,
Have a similar elm cable as the one posted previously.. slight changes. have the same issue, cant connet to can modules on alfa 147 selespeed 2001 model. Do i remove the resistor as posted ain response above.
Much appreciated. thanks, cheers
Hello MF07
Your Image ist very small
I can not read the numbers of Chip
I think you remove the Resistor in the red Frame
than you can read the CAN Bus Protokoll with your Alfa 147
20150207_212631 markiert.jpg (86.29 KiB) Viewed 7490 times
I have buy the same ELM
At two weeks I can see and testet
leeg123007
Post by leeg123007 »
hello I am hoping someone can help I have just bought of ebay a cable to connect to my fiat 500 airbag system anyway I will connect to the engine ecu and the abs ecu but not the airbag ecu the one I have is marked up multi scan ecu then under that it says modified elm also can anyone inform me how to add photos on here thanks lee
