Page 167 of 257
Posted: 02 Feb 2015, 04:56
by cxem
1.BK3231Q + MCP2515 + TJA1040 can not speak the language of the Palio 2004.
2.Palio 2004 no language OBD?
Posted: 02 Feb 2015, 08:56
by blkid
Ok, checked on alfa 159 and, as supposed, it was not possible to connect to anything. In addition, when i try to connect with multiecuscan at the engine ecu or with torque, turn on several anomalies:
- Airbag avary reported
- Abs/vdc avary reported
- water temperature gauge at full scale
- fuel gauge to zero and with reserve warning light blinking
This is the output of scan with multiecuscan:
RESPONSE:
ATZ
ELM327 v2.1
ELM327 v2.1
RESPONSE: ?
RESPONSE: ?
RESPONSE: ?
I think in addition to sw buggy there is something wrong in the hw, and I always refer to the components that I have said in previous posts!
Posted: 02 Feb 2015, 10:39
by Waltomatic
KillBill: Palio 2004 with 3-pin????????? Here in Brazil the previous models already used the OBD2 connector for years...
Your car does not have the OBD connector in the fuse box?
Posted: 02 Feb 2015, 15:23
by boch
typical situation while connecting to ABS/ESP module i think. i found the same problem with USB interface.
Posted: 02 Feb 2015, 15:31
by blkid
The failures reported occur simultaneously
Posted: 02 Feb 2015, 20:38
by KillBill
@ Waltomatic
This Palio uses IAW 4sf-pc ECU with 3 pin connector (this is a original module from Fiat).
Below I attached one picture about the fuse box:
- Fuse Box.jpg (57.98 KiB) Viewed 9319 times
Look the ECU informations:
- ECU.jpg (40.81 KiB) Viewed 9319 times
The ELM 327 only requires that the led + be connected on battery (pin 16 on OBD connector)
The negative that is used comes from the 3 pin connector (pin number 2).
The K line from ECU goes to pin 7 of OBD2 connector.
- 3 pin conector.jpg (112.74 KiB) Viewed 9319 times
I've checked on the supported veicules and under Palio I didn't see the 3 pin being used in any of Palio's models.
Could you have used Multiscan in these kind of connection ?
Thanks in advance
Posted: 02 Feb 2015, 22:45
by Waltomatic
OK, but I was really suprise: Brazil earlier than Europe?
The IAW 4SF family always used OBD connector here, including the Palio 2008 of my son.
In theory, I think it should work.
Posted: 03 Feb 2015, 22:06
Hello Kill Bill
As Walter writes, it is strange that your Palio `04 has a 3 pin diagnosis connector.
But if it is so, then good
But the Palio is not read your ECU via CAN bus
therefore remove the resistor to read the engine control is unnecessary
It must also go so
Just try this driver
Posted: 04 Feb 2015, 00:21
by KillBill
Alfaeddy wrote:Hello Kill Bill
It must also go so
Ok Alfaeddy.
I am receiving a Vag Com dongle (USB) and I will try to connect with the ECU.
Thanks for your help.
Posted: 04 Feb 2015, 12:24
by dodo
@Alfaeddy,
My car is a Alfa 159 1.9 JTD Build Year 2007. I cannot connect with this interface.
Do i have to remove an resistor ? Please help. Thank You!
- IMG_20150204_131737.jpg (24.67 KiB) Viewed 8557 times
- IMG_20150204_131608.jpg (1.59 MiB) Viewed 8557 times
