Page 153 of 257
Posted: 07 Nov 2014, 16:34
by PuntoHGT2002
Look my Name: Fiat Punto 188 HGT 1.8 Bj. 2002.
I can See the engine control Unit (in german steuergerät) But Not the boardcomputer. I Know that i need the Yellow Adapter for read the boardcomputer.
Greetz
Posted: 07 Nov 2014, 18:23
Hi PuntoHGT2002
Oh, so this confusion :?
For your Punto you do not need a yellow adapter
Just look after here
You have written an article in which you have the abgeblidete ELM Interface !!
Did you also remove the marked resistor ??
In order to clarify
For your Punto need no adapter for the ELM
The engine control unit (KWP2000) read with any protocol other than
the body computer (CAN bus)
To read the CAN bus protocol must be removed this bridge resistor.
This has been described here in this thread already 100 times
For ABS and airbag you need a KKL interface with Adapters
Posted: 07 Nov 2014, 19:08
by Bigio80
Today I have recived the new interface ELM327 who kindly Amazon seller sent me after I told him that the already received did not work.
This new work perfectly and seems to be the same in all (board and chip unit) at the first than don't work ("Connection timeout" message).
I have done the modify of remove resistence and I can connect with all CAN and non CAN module of my FIAT PUNTO 2012.
So...when I say that interface based on CH340T chip can't work is not a true.
After many hour spent trying to make the faulty interface work in some way, I can say one thing: if don't work very probably is a faulty one...ask
seller to refund or to send another (they know very well that a lot of they interface NOT work).
Posted: 07 Nov 2014, 19:28
by PuntoHGT2002
I don't. Know how this is possible But it works now. I'm sure that i've tryed without Adapter, Too and it doesnt works.
Thank you at all.
Who can i buy the kl interface?
Greetz puntohgt2002 from germany
Posted: 07 Nov 2014, 22:06
Hi Punto
Ach du bist aus Deutschland
Dann ist es auch für mich einfacher zu beschreiben , was Sache ist.
Hast du den Namen auch in anderen Foren , dachte nähmlich den Namen kenn ich doch ???
Ein KKL bekommst du hier in dieser Version benötigst du auch keine weiteren Adapter
http://www.ebay.de/itm/151015653820?_tr ... EBIDX%3AIT
Gruß Eddy
Posted: 08 Nov 2014, 00:42
by leandroserra
Alfaeddy Sorry for being generic.
Informations follows :.
Punto 1.4 Tjet
2010
I tried to use the software: EOBD Facile, Torque (free), OBD Car Doctor Free, DashCommand and Carista
Everyone in my Android 4.4.2
thanks
Alfaeddy wrote:Hello lean...
Unfortunately, we are not clairvoyant :? :?
Androit? :shock:
What software do you need to read your car ??
Multiecuscan is not for use with Adroit. !!! :?:
Which vehicle? :?:
What Bj. :?:
Which engine? :?:
This is about Italian cars and the software Multiecuscan. :!:
Without any details, we have rates :?
Posted: 08 Nov 2014, 06:24
Hello Leandroserra
This software I do not know, except Torque
And use them not because they help to little
It can only read Emissions-related data.
Therefore, help is not possible here
Posted: 11 Nov 2014, 23:12
by vmaci
I got ELM USB v2.1. I removed resistor 122 Om but MES is not understanding this ELM.
In test I have result what it can't work with CAN. When I will try to connect I have error.
In what could problem
A lot of thx.
Posted: 12 Nov 2014, 09:49
Hello Vmaci
On some ELMs there are 2 resistors 121 if you have the right away
You can find the many boards that have been marked here in this thread I recognize
Have removed only by your statement that you have a resistor (122?), You can not say something here.
Very often the connection problems are also present, settings, drivers, and connections.
Posted: 13 Nov 2014, 22:06
by vmaci
Thanx for so quick answer, I wrote wrong what it ELM USB. I have ELM BT v2.1. which don't want connect to ECU.
