budgoz
Post by budgoz »
GTEX wrote: 18 Nov 2025, 23:28
budgoz wrote: 18 Nov 2025, 13:31
GTEX wrote: 16 Nov 2025, 13:28 Hello everyone, I have a 2019 Fiat 500 Lounge with Uconnect 7" and a single USB port. I have tried all the proxy codes I could find to activate Carplay without success. I reverse engineered the bytes but couldn't get it to work.
My configuration from the Engineering menu:
Serial OTF191083901276, SW Version 23.00.81.03, HW Version D6, Checksum (CRC), 7d8e
Hardware release 0.32.5.1, Firmware release 0.0.0.2, Serial number OTF191083901276, Production Date 2019-03-24
HWariant DAB eMMC GPS S&S USB BT LS CAN MIC1 dMIC 9V PhtSupl DT, FP
USB : 0x30001:Hub [2 Ports], 0x30102:Unknown Device, 0x30101:Mass Storage
My proxy stock :
33 32 31 35 30 30 34 36 36 37 39 4F 55 54 50 55 54 44 4A 49 54 20 18 12 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 C7 71 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 82 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 94 00 22 00 04 88 00 00 20 80 00 00 44 00 D5 00 0F 00 00 00 00 01 00 60 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
193 bytes with uconnect on 44 and USB byte 115 on 00. I changed it to 05 01 01 and USB to 04, but without success. When I connect my phone, I have mobile phone display options that appear with iPhone, but when I click on them, nothing happens.
Excel Drive link for byte comparison: https://1drv.ms/x/c/cc9bc4f3da1db915/EQPHSG6-iuNHgD_NkPnBWOYBOd-eZimcQdsRJ4DVtrAU8Q?e=tuZUZ9
Does anyone have any ideas or could share their proxy code for a Fiat 500 or Abarth with a single USB port?
@Romain did you find a solution ? we have the same uconnect byte 44 and I did not see a lot this byte.
unfortunately not all Uconnects 7" have the hardware for the Carplay.
Anyway your best shot is to update the firmware first (link: https://drive.google.com/file/d/1Y4irT-r9_FgREHnCzB6YPCEZ3VQtspgH/view?usp=sharing).
You need to extract all the fies in the root folder of a USB drive formatted in FAT32. After you insert it and wait for 60 seconds, the Uconnect will prompt you to start the update. It takes approx 30 minutes, you better do it while driving or with the battery connected to a charger. DO NOT TURN THE DASH/UCONNECT OFF DURING THE PROCESS.
After the upadte is done, you can try again with the proxy alignment.
You don not have the AUX port, right?
My suggestion is the following version:
33 32 31 35 30 30 34 36 36 37 39 4F 55 54 50 55 54 44 4A 49 54 20 18 12 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 C7 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 82 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 94 00 22 00 04 88 00 00 20 80 00 00 44 00 95 00 0F 00 00 00 00 01 00 C0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Fingers crossed.
Thanks for your reply and your time to help me. Yes, I think I don't have the right hardware for CarPlay, even though the car was built in 2019.
I don't have an aux port; I only have one USB port.
I'm still trying to find a solution and I wondered if CarPlay doesn't work, maybe Android Auto does. I tested it and it works!
I was inspired by this post: https://www.forum-fiat-tipo.net/viewtopic.php?f=22&t=2129&p=25611&hilit=carplay#p25611 (French version).
He uses an Android Auto AI box that can emulate CarPlay with a passthrough Android Auto.
I'm going to buy one and test it to get CarPlay. Maybe other peoples tried this option ? and can be able to use CarPlay on a large screen.
If Android Auto works, Carplay 100% works as well. It might be a cable issue, did you try with an originale one? And did you check if everything is enable on the iphone side?
GTEX
Post by GTEX »
budgoz wrote: 22 Nov 2025, 17:21
Fingers crossed.
I tried different cables and iPhones, an OEM MFI cable and a CarPlay stick, but nothing works. I'm sure I only have Android Auto, which is strange. I tried using byte 160 at 00 (known to activate Android Auto with 01), and Android Auto worked. So I don't understand.
Sofoklis500araki
Post by Sofoklis500araki »
Hi GTEX,
Try to change byte 130 from 01 to 05, it gonna change the look from fiat to Abarth, I had the same issue with you and I saw this 2 times when I put for my friends Uconnect 7 from uconnect 5. After I did this change the CarPlay start working normally ! I hope help you!
GTEX
Post by GTEX »
Sofoklis500araki wrote: 12 Dec 2025, 20:35 Hi GTEX,
Interesting, but unfortunately I changed this byte and CarPlay still doesn't work. I use an adapter for CarPlay to Android Auto, which works with CarPlay in full screen mode.
Thanks for your feedback!
marribo1
Alfa Mito Alignment Question
Post by marribo1 »
Have the dreaded flashing odometer and someone replaced the Uconnect5, my current canbus data is
CAN CONFIGURATION DATA:
4F 84 00 05 11 00 00 00 4F 84 00 05 11 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 84 00 05 11 00 00 00 09 04 00 04 11 00 00 00 4F 84 00 05 11 00 00 00 09 04 00 04 11 00 00 00 09 04 00 04 01 00 00 00
30 31 31 34 35 30 31 39 37 34 31 4F 55 54 50 55 54 44 4A 49 54 20 14 09 10 4F 84 00 05 11 00 00 00 09 04 00 04 11 00 00 00 D7 C0 71 07 67 10 61 20 00 00 00 2F 07 05 00 9C 06 35 01 28 00 00 52 40 7A 41 0A 5C 0D 00 00 00 55 00 00 00 00 39 02 81 05 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 8E 12 00 10 00 00 02 48 00 07 00 00 00 00 00 00 03 B3 00 92
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Tire Pressure Node (TPMS)
(Multiecuscan 5.4)
Question is i tried changing Byte 123 from 07 to D5, 11 and 15 but didnt make any difference ....any ideas on how to stop getting the out of range error would be appriecated
Alfa Romeo MiTo 1.6 JTDm 16V
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
Tire Pressure Node (TPMS): EOL Ok
Entertainment Telematic Node (ETM): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Tire Pressure Node (TPMS) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Request out of range error
[102A] errors: Byte 123: 07->03
FAILED TO EXECUTE
abarthmultijet
Re: Alfa Mito Alignment Question
Post by abarthmultijet »
marribo1 wrote: 15 Dec 2025, 21:24 Have the dreaded flashing odometer and someone replaced the Uconnect5, my current canbus data is
(Multiecuscan 5.4)
FAILED TO EXECUTE
The solution is in your answer. Change byte 123 from 07 to 03
marribo1
Post by marribo1 »
abarthmultijet wrote: 17 Dec 2025, 21:36
(Multiecuscan 5.4)
FAILED TO EXECUTE
Wow didnt notice that was the solution! so easy thanks :D
foloap
Post by foloap »
hi guys
I pimped my girlfriend's 500 2018 with the uconnect 7'' (vp2 ECE DAB GPS sw 23.03.67.12 HW F.EU.D8.V28).
No GPS or DAB antennas are currently installed
I run proxi alignment and changed some bytes as I found on vk2 site, the odometer does not blink anymore but carplay and android auto are not working (AUX + 1 USB port on the tunnel). I tried different cables, could you help me with the proper coding?
This is the original proxi before the alignment
33 32 31 35 30 30 33 35 38 33 32 4F 55 54 50 55 54 44 4A 49 54 20 18 01 11 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 01 C2 73 06 DB 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 94 00 22 00 04 88 02 00 20 80 00 00 30 00 81 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
After the alignment with some bytes changed as per vk2 site guide
4F 80 00 04 10 00 00 00 4F 80 00 04 10 00 00 00 4F 00 00 04 10 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00
33 32 31 35 30 30 33 35 38 33 32 4F 55 54 50 55 54 44 4A 49 54 20 18 01 11 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 01 C2 73 06 DB 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 94 00 22 00 04 88 02 00 20 80 00 00 40 00 81 00 0F 00 00 00 00 01 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
(Multiecuscan 4.8)
3/29/2026 2:17:56 PM
Fiat 500 1.2 8V
Thank you :)
foloap
Post by foloap »
I tried other cables but nothing, CarPlay or Android auto don’t pop up.
I asked for support to a specialized shop and they suggested me to replace the USB module on the tunnel from type 2 (AUX + USB) with the module with the 2 USB ports (type 4?). Should I change the cable between uconnect and the module as well?
Any suggestion is more than welcome :)
