Page 144 of 257
Posted: 29 Sep 2014, 09:07
by hlqq
¡¡¡¡Thanks a lot!!!!!!!
hlqq
Posted: 29 Sep 2014, 19:42
by Matees
I try to solve my problem. I have Alfa Romeo 159 and I would like to connect to airbags via my ELM327 BT interface. Connection to engine is working well. I spent here some hours, so my question is: Shall I remove resistor 121 after making 2 parts from one interface? I think, that there is a Picture of similar interface here: viewtopic.php?f=5&t=1493&hilit=bluetooth&start=1280
I attach some pictures of my interface, but it's almost nothing to see...
Thanks in advance for your help.
Posted: 29 Sep 2014, 21:27
Hello Matees
The bridgeresistor sits on the lower PCB
and is designated R2.
Your boards are soldered together but unfortunately
therefore you get very difficult at this resistor
With some skillful of bridgeresistor has to be removed anyway, even without the boards to separate
I have this already made ​​this mini ELM
WP_20140929_006 markiert.jpg (116.23 KiB) Viewed 11187 times
Posted: 01 Oct 2014, 12:47
by Matees
Hi Eddy,
thanks a lot for your quick help. Resistor is out now. I will check it tomorrow on my car.
Posted: 03 Oct 2014, 19:29
by Herpez
Hi friends...
Sorry for such a noob question but how to you open the elm327 to access the board?
Do you cut the plastic?
Mine is this
Posted: 03 Oct 2014, 19:47
hello
Opening the is comparatively easy
simply press lightly with a sharp knife into the space around the casing of an other to solve
In part, the glued
others are just clipped
and immediately go apart
Posted: 03 Oct 2014, 22:42
by Herpez
Here is my board.
Can you tell me what resistor needs to go out?
Posted: 04 Oct 2014, 07:24
hello
Wow, now that's a violent opening :D :D
The components on the board are very difficult to detect
unfavorable angle
But the R2 should be the bridge resistance
There are in this thread several times already this ELM Interface
The second picture is for comparing
IMG_20141003_233836 markiert.jpg (128.39 KiB) Viewed 11119 times
ELM mini markiert.jpg (225.77 KiB) Viewed 11119 times
Posted: 04 Oct 2014, 17:07
by Herpez
Alfaeddy wrote:hello
unfavorable angle
Greetings
Thanks found the r2 but seems impossible to get there. Is possible to detach the two boards or are they soldered?
Posted: 04 Oct 2014, 18:54
Hello Herpez
The two boards are soldered correctly
If you are careful you can break out the resistor with a stable needle. But beware that the interconnects do not break.
You can also with a desoldering pump desoldering the solder joints and separate the two boards.
Remove resistor and solder the boards again
