Page 141 of 257
Posted: 27 Aug 2014, 12:55
by Waltomatic
libertyt8 wrote:1. I can't see datas which in this photo
2.I can't see like these options " Bady, Service, Other"
Here in Brazil, Marea never had these options.
Where are you from?
Posted: 27 Aug 2014, 14:47
by us911
Alfaeddy wrote:hello libertyt8
Which vehicle?
And as already written, remove the white plastic base on the 8pin bar and take a picture of it
Isn`t it R02 on the backside of the board?
No need to remove the plastic base,I guess.
Greetings
Uwe
Posted: 27 Aug 2014, 19:51
Hello Uwe
correct R2 :oops:
Have not looked closely enough I ;) :)
Posted: 27 Aug 2014, 22:51
by libertyt8
Where are you from?
Turkey. I now understand.
Thanks.
us911 and Alfaeddy,
very very thanks.
Posted: 28 Aug 2014, 17:45
by angelu80
I am trying to connect a ELM 327 Wifi to my Giulietta MY2014. It is a 1.4 Multiair engine and TCT gearshift. I am able to connecto to engine, ABS, Gearbox, and Steering. However, I am not able to connect to any other ECU, like Service or Body computer. I have tried with the yellow adapter, but it does not make any difference...
Is there any solution for my device?
Thank you in advance!
[img][http://postimg.org/image/jb88srcmv/][img]http://s15.postimg.org/jb88srcmv/IMG_0347.jpg[/img]
[img][http://postimg.org/image/h2pp1b7fx/][img=http://s22.postimg.org/h2pp1b7fx/IMG_0344.jpg][/img]
Posted: 28 Aug 2014, 19:19
Your yellow adapter must be defective
because the controls for that you need the adapter you get no connection.
Without the adapter, everything works
Shake times easily by the plug, the adapter may have contact problems
Your linked images, I can not open, why?
Posted: 28 Aug 2014, 19:26
by Waltomatic
Alfaeddy wrote:
...Your linked images, I can not open, why? ...
For this, I can help, but...
:lol: :roll: :oops: :mrgreen:
Posted: 31 Aug 2014, 08:11
by Wasdeo
Hello. I just received my elm 327 BT 1.5
It turns the led on after connecting it to the car but then it goes off. Could someone point me on which resistor should I remove? Thanks.
http://i.imgur.com/dEPvNuo.jpg
http://i.imgur.com/98DUNER.jpg
Posted: 31 Aug 2014, 09:53
by edgarss24
Hi.I have problem with my ELM327 interfaces.I can not conect to dashbord, servise and body computer.Could someone point me on which resistor should I remove or what I should do?
Posted: 31 Aug 2014, 09:55
by edgarss24
Aditional photto.
