This resistor right?Alfaeddy wrote:Hello Zafron
Your pictures are very very very bad , Sorry![]()
In the first picture of the Mini ELM I can not see anything
The upper board is installed, the you need can pull off
You should not use flash when taking photos.
But again, the bridge resistance only affects CAN bus protocols
So the Punto of 2000 must be read with the resistance MotorECU.
As I have already written, I know only the plug contacts
to be separated without soldering
Edit:
The ELM of Zafron is also plugged, with a slight train and move back and forth, there should be separate
Edit:
I'm afraid of break all pulling it strong but i'll try.
I think my elm is really soldered, not plugged. I will try move it back and forward.
Edit: Doesn't work unless I brake the connectors. I think I will sawing them.
In fact i think i'll unweld the pin
If the pins are not plugged in
then unsolder the pins on the top board
I know it could seem strange but the pins are plugged in but it's impossible unplug them. I also tried with a vice and pull with a tongs!
Oh dear, with a vice or pliers ???
These are not tools to work on boards
Don't worry obiouvsly i took the caution and ddin't damage nothing. I only made you understand that pulling wasn't enough.
Ah ok , i understand it
