budgoz
Post by budgoz »
Panya wrote: 05 Jul 2025, 07:00
budgoz wrote: 10 Oct 2024, 10:25 I need to know if the sport mode gets activated first. Also do you have the 7inch radio (big screen) without carplay?
Hi.
I have Uconnect5 with a small screen.
I tried your proxy, where byte 83=00, 44=75, 65=20. Now the ECO button works as the Sport button.
Thank you very much!
Tell me how to make the tachometer display circular like on the Abarth when the Sport mode is turned on?
Good to hear.
Try this:
Proxy n.2
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 75 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 80 05 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Proxy n.3
33 32 31 35 30 30 34 32 39 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 09 20 4F 80 00 05 14 00 00 00 09 00 00 04 10 00 00 00 03 C2 75 06 F4 00 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 68 03 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 00 22 00 04 88 07 00 20 80 00 00 30 00 81 00 0F 00 00 00 80 05 00 40 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
finomm
Post by finomm »
Does anyone have any information for the proxy alignment from ucconect 5 to ucconect 7 for a fiat 500X (2017)? Thanks.
Ladware
Post by Ladware »
Hi everyone,
I’ve read through the whole thread but unfortunately didn’t find any information useful for my issue.
Here’s my problem:
I'm from Italy and I have a 2015 Abarth 500 with the facelift dashboard. The head unit is an aftermarket Android radio with its own CAN bus decoder.
Everything works perfectly — steering wheel controls, rear camera, door open warnings, etc. — but the odometer keeps flashing.
I did a proxy alignment and the ETM node shows an error.
If I disconnect the head unit, the proxy alignment completes successfully and the odometer stops flashing.
As soon as I reconnect the head unit, everything works again, but the odometer starts flashing once more.
Previously, my proxy was this:
33 32 31 35 30 30 31 33 35 38 31 4F 55 54 50 55 54 44 4A 49 54 20 15 04 09 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 77 06 FE 00 1C A0 BA 80 00 16 00 01 00 94 06 01 01 00 00 00 00 30 79 41 0A 0C 0D 00 80 00 23 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
Then I tried this one:
33 32 31 35 30 30 31 33 35 38 31 4F 55 54 50 55 54 44 4A 49 54 20 15 04 09 4F 80 00 04 00 00 00 00 09 00 00 04 00 00 00 00 81 82 77 06 FE 00 1C A0 0A 90 00 16 00 01 00 84 06 01 01 00 00 00 00 30 79 41 0A 0C 0D 00 80 00 23 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
But the problem persists.
Any ideas? Anybody can help me? Thanks in advance!
DragonTek77
Post by DragonTek77 »
Greetings! I am hoping someone might be able to offer some assistance with a situation I am experiencing. I have a 2012 Fiat Abarth and have installed a TFT display from a 2015 Abarth model. Initially, everything appeared to be functioning correctly. However, during the proxy alignment process, I neglected to save the hex code as a precaution. After performing the proxy alignment, I noticed that the TPMS information screen is no longer displaying, even though it was working prior to the alignment. Furthermore, I am now seeing several warning lights illuminated, including "ECS," "ABS," "Service Power Steering," "Service Airbag," and "Service Brake System." Despite these issues, everything else seems to be working, such as the Abarth theme and boost gauge. I am unsure of what may have gone wrong.
The current code displayed is:
31 32 31 33 38 30 37 37 37 30 30 31 32 33 34 35 36 37 38 39 30 20 12 06 30 6F 80 00 04 03 00 00 00 29 00 00 00 03 00 00 00 80 F2 4F 06 F4 40 01 71 AA 16 00 66 00 09 00 94 03 00 02 00 01 80 00 60 00 00 00 00 00 00 00 00 27 00 00 00 00 31 06 51 01 00 00 68
budgoz
Post by budgoz »
DragonTek77 wrote: 29 Aug 2025, 02:28 Greetings! I am hoping someone might be able to offer some assistance with a situation I am experiencing. I have a 2012 Fiat Abarth and have installed a TFT display from a 2015 Abarth model. Initially, everything appeared to be functioning correctly. However, during the proxy alignment process, I neglected to save the hex code as a precaution. After performing the proxy alignment, I noticed that the TPMS information screen is no longer displaying, even though it was working prior to the alignment. Furthermore, I am now seeing several warning lights illuminated, including "ECS," "ABS," "Service Power Steering," "Service Airbag," and "Service Brake System." Despite these issues, everything else seems to be working, such as the Abarth theme and boost gauge. I am unsure of what may have gone wrong.
Is it possible you installed a TFT from the EU market on an US car model?
DragonTek77
budgoz wrote: 29 Aug 2025, 10:43
Nah, both models are from the US. I got my TFT from a local salvage yard. My wife has a regular 2015 Fiat 500, and if I copy and paste her hex code over, I get the TPMS screen back, but the lights are still there.,
rodspower
Post by rodspower »
Share with us the part number from the previously Instrument Cluster and the new one.
DragonTek77
Update: I managed to find the backup file in the MES program. I didn't know MES saved every proxy you do in a text file. I got all the lights to disappear. The only thing I still don't have is the TPMS screen that shows all the pressures; that is still missing but everything else works fine
toinouu77
Post by toinouu77 »
Bonjour à tous.
Je n'arrive pas à activer le Carplay sur ma Fiat 500 1.2 de 2016 qui dispose du Uconnect 7.
La version de mon Uconnect 7:
ECU ISO code : 00 24 70 55 15
ECU serial number : TD3401666014330
Software version : 2101
Mon proxy actuel :
33 32 31 35 30 30 31 39 33 36 31 4F 55 54 50 55 54 44 4A 49 54 20 16 06 16 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 73 06 F4 00 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 11 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 94 08 52 00 04 88 02 00 20 80 00 00 44 00 D5 00 0F 00 00 00 00 05 00 E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
J'ai modifié le byte pour avoir l'écran Abarth et cela fonctionne parfaitement mais pas le Carplay malgré l'ajout du 01 au lieu de 00 sur le byte 157 et 160.
Merci par avance pour votre aide précieuse.
aam583
Post by aam583 »
I have a 2012 USA Abarth 500 and just ordered a TFT from a 2017 Pop. There seems to be a lot of info around the MES procedure, but a lot of it might be outdated since its a few years old. What's the current best practice and sequence for getting this done correctly? Any consensus on what the bytes should be to have most functions still working for the Abarth? Any known functionality that I will lose from the current LCD cluster? Thank you.
