I have some questions
Which diagnostic interface?
Which driver?
Have you made all the settings? (Latency to 1)
If you installed the interface your press times to test
and do a screenshot on it.
Which driver?
I bought it on ebay so I dont know the real name, but "elm327".
driver:
CP210x_VCP_Win_XP_S2K3_Vista_7
PL2303_Prolific_DriverInstaller_v1.8.0
latency? i dont know nothing about latency, but the speed is on 38400.
driver:
This interface I have:
http://www.ebay.com/itm/360624259557
Here you can find everything what needs to be done.
http://www.multiecuscan.net/HowToUse.aspx
The latency must be set to 1.
Control Panel / Device Manager / comport / Properties / extended
where the latency of the Comports change!
But is also available in the User Guide
Thanks for the link, I am going to look into this.
What is the difference between CAN bus, and non CAN bus?
According to this chart I need VAGcom or OBDKey.
It doesn't work with ELM?
No with this ELM you can not connect.
Buy yourself a KKL interface
I've overlooked in your first post
Sorry
Sorry
Thank you for your reply. One more question
In the settings when I push the test button, it say: The interface is compatible with ELM 327 1.3+. Should connect properly with all CAN modules.
so that resistor doesn't help me? :S
http://www.ebay.com/itm/New-Car-Diagnos ... 5662dd28d1
I found this vag cable, but: The CVFG-A11 cable can not work if your car uses a protocol bus system like VPW, PWM or CAN -bus
mikcsek wrote:http://www.ebay.com/itm/New-Car-Diagnos ... 5662dd28d1
This Kabel is Ok for your Bravo
The Bravo have not VPW , PWM or CAN Protokoll
