celenlee wrote:1- The 121 Ohm resistor formed a bridge between pin 6&7 of MCP2551 (Pin 6-14 of OBD), and I removed this.Alfaeddy wrote:Hello celenlee
First off, your remote Resistor has formed a bridge at pin 6 & 7 of MCP2551?
Not einface remove a resistor if you do not know what this is. !
Then another, what car / control you want to read?
Because the resistor prevents only the CAN bus or not combined!
No other logs
And even if you can not make a test interface, this is due to your wifi
Connection and not your vehicle connection
2- I want to use this interface on Grande Punto. (Engine ECU and Selespeed ECU)
When I look at the board I do not see the 100Ohm Resistor+ 560pF cap. ?
Is it true to add these missing parts to use on Grande Punto?
At 1 Yes
Ad 2 You can read without the yellow adapter
This pass (resistor + capacitor) was still required for any of my many ELM Interface!
Either the settings is incorrect
or the ELM is defective.
