pirignogno
Post by pirignogno »
BrackoNe wrote:@elchip
Can you tell me where can I buy original Chip? Some Internet store which is able to send me chip in Serbia?
Hi, I suggest you take it directly from who produces it and you're sure you'll you get a chip original
http://www.elmelectronics.com/orderform.html
Fiat Stilo 3 porte 1.9JTD Dynamic '03
pandamatic
Post by pandamatic »
Yep, just modded my Ebay Elm 1.4 in this way, even though circuit board was different. Now I can access the CAN network and reset the service message. (after paying for registration)
Love it when you get genuine help that makes real progress.
BrackoNe
Post by BrackoNe »
Sorry for being so borring, but which one should I buy?
ELM327 v1.3a
OBD to RS232 Interpreter
ELM327 v1.3a
OBD to RS232 Interpreter IC
and a MCP2551 transceiver IC
ELM327 v1.4b
ELM327 v1.4b
And the last question (I promise that I will not bother you anymore :) ) is this full box (motherboard/cables), or only the chip which I need to put on my existing board?
I alredy have cables from ODB to RS232 and to USB.
Thanks in advance, and sorry for bothering you... :)
osmangdk
Post by osmangdk »
I have ELM327 v1.4a.(by on- board.). I've Alfa 147 2.0 Selespeed.I want to connect to Vdc,ABS.
multiecuscan.Net -->Supported Vehicles diagrams--> ELM327--> Table Adapter1(ELM1).
I do ELM1 (1,7,9,12 pins bridge).But,ELM327->Cannot ecu.Check serialports and pins.
I can ecu and automatic transmission.Did I something missing?
Otherwise,Do you need to VAG-COM to buy.
My car is error VDC.When I turn the car off,error is lost(disappear).When I use the AC(air conditioner), lamp on,occasionally.
HELP ME!!!
Forgot to ask you, do you have installed DIP switch o your ELM or you using adapter cable #1?
osmangdk
Post by osmangdk »
I make adapter cable1,but don't use.
I Don't know DIP Switch.
R04 not destroy.
If,I removed r04 ,does it work ELM327.
Thank you for everything.
I have ELM 327 interface as shown on page # 6 of this topic:
viewtopic.php?f=5&t=1493&start=50
I had to remove resistor 04 because it did not worked! When I removed the resistor my ELM327 interface started to work!
If your EM327 interface is same as shown on page #6 than you should remove resistor 04.
But if your EM327 interface is not same as shown on page #6 do not remove resistor 04.
Did you tried to connect your adapter cable #1 to your ELM327 and then to a car?
Then you should connect FES to ABS system of your car...
osmangdk
Post by osmangdk »
Hi. Thank you for answering my questions.
I added board photos ELM327.
There are two things in a different resistance.
How do you think?
Do you think should remove R04.Thank you.
ELM327 V1.4+ mi acaba :)
ELM327 V1.4+
ELM327 V1.4+
mattydr67
Post by mattydr67 »
Hi m8
Yes remove the resistor R04 like Mr. Alfa156sarajevo said and all will be ok.
You're interface will start to work on CAN
osmangdk
Post by osmangdk »
Thank you for everything.I tried.
