Ducato 8 (model 2022)
chrener
Re: Ducato 8 (model 2022)
Post by chrener »
Dino1965 wrote: 28 Apr 2022, 07:34 Thank you.
Due to a different Body Computer in the newest Duc8 (new Marelli/Delphi instead of Marelli 11, with different CAN adress) it (at least for me looks like it) will not possible to read the proxy with multiecuscan for now(?).
But i can read it with AlfaOBD (ELM327 without any Adapter, for most other control modules the grey adapter is needed, not the yellow!). It shows values which seemed to be very different compared to the older models:
38 32 32 39 35 30 30 30 36 36 39 4F 55 54 50 55 54 2D 53 49 54 20 21 10 15 4F 0C 40 C5 10 02 04 00 00 00 00 00 80 00 01 00 4F 0C 40 45 10 00 04 00 00 00 00 00 80 00 00 00 51 D1 29 02 68 40 08 DD 14 33 23 06 4A 43 01 01 53 60 00 02 81 05 10 00 30 43 02 04 19 8C 08 00 ED 03 07 98 86 03 11 E9 00 00 18 24 00 01 00 71 EB 9D 06 ED 00 53 08 04 84 18 00 40 80 07 00 B7 00 F5 02 15 2A 00 00 00 04 14 F8 7A 01 B5 00 01 00 00 00 00 05 14 40 11 00 26 04 00 00 00 00 00 00 00 00 01 01 C0 01 00 40 20 0C 80 20 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 03 00 00 08 10 00 1E 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I'm now looking for someone who can link the Bytes to it's functional meaning.... :-)
BR, Andreas
Hi!
what do you want to know?
And please can you send me list of yours can modules???
They are in MES log file...
Dino1965
Post by Dino1965 »
chrener wrote: 09 May 2022, 07:15
Hi!
Thank you.
Well I already got the information I needed concerning the tank size (byte 67).
But have to switch to AlfaOBD due to the lack of Duc8 support in MES, even in the newest 4.9 version.
In principle works fine so far but still some problems with proxy alignment for 1 module.
BR
List of modules:
Body Computer (BCM)
Engine/Powertrain Control (ECM/PCM)
Electric Power Steering (EPS)
Instrument Panel Cluster (IPC)
Anti-Lock Brakes (ABS)
Heat, Ventilation and Air Conditioner (HVAC)
Transmission Control Module (TCM)
Electronic Shift Module (ESM)
Parking Assistant Module (PAM)
Entertainment Telematic Module (LTM/ETM/HTM)
Integrated Center Stack (ICS/HCPM)
Entertainment multimedia control module (EMCM)
Occupant Restraint Module (ORC)
Haptical Lane Feedback Node (HALF)
looks like missing 3 more modules
just paste or attach log with "CAN CONFIGURATION DATA:"
Dino1965
Post by Dino1965 »
shpuncik wrote: 10 May 2022, 15:40 looks like missing 3 more modules
PRESENT CAN UNITS:
Body Computer (BCM)
DSM
DCU (SCRM)
______________________
CAN UNITS WITH EOL IN PROXY:
Body Computer (BCM)
Note: SGW not build in during the scan
now that's correct
chrener
Post by chrener »
What does it mean? DSM & DCU (SCRM) ???
Heiha9
Post by Heiha9 »
Given it's one year later, does MES support Ducato 8 now?
I'm specifically interested in enabling the reverse camera button on the 10" display. See attached image, the camera icon in the top left bar. Mine only activates with the reverse gear.
Also, is there a way to activate Uconnect services as a whole? Mine does not even come with "My Assistant", the most basic Uconnect service.
