Convergence Telematic Module (Blue&Me) Removal
DaveDevil
Re: Convergence Telematic Module (Blue&Me) Removal
Post by DaveDevil »
You can PM me after 11 July, or for sure I'll forget it :roll:
JDalfa wrote: 28 Jun 2021, 13:11 Ok maybe you can let me know when you’re back home.
Or if anyone else can help please let me know!
Thanks!
go to proxi settings, press Ctrl+Alt+C and there you can edit your proxi manually
JDalfa
Post by JDalfa »
Tried that with simulation, so i just change the 38th digit combinition i count from 42 to 02?
Thnx!
DaveDevil
Post by DaveDevil »
Yes. Be sure to backup your original proxy so in case of problems you can roll it back
JDalfa
Post by JDalfa »
Thanks, gonna try that! Also disconnect the radio with battery disconnected?
DaveDevil
Post by DaveDevil »
Sure, better that way
JDalfa
Post by JDalfa »
It worked perfectly, thank you!
Is there a list of the custom proxy digits, wat they do/mean?
Kind Regards joost
DaveDevil
Post by DaveDevil »
I wish it were, things like that are the holy grail, and who knows that things usually keeps it secret, donating only few drops once in a while...
Jeff1985
Post by Jeff1985 »
Hi. Did you manage to do a proxy alignment without your blue and me?
Mine is faulty so it’s made the mileage flash. Keep trying to do an alignment but it fails when it try’s to do the convergence telematic node. Can I change the code so it thinks it’s not there?
DaveDevil
Post by DaveDevil »
Jeff1985 wrote: 20 Oct 2022, 12:43 Hi. Did you manage to do a proxy alignment without your blue and me?
Yes. Follow the video in the older posts, then disconnect your module while you disconnected the battery. Then do an alignment
