GIULIA/STELVIO Addition to front parking sensors in Proxy adjustment
Gianmarco
Re: GIULIA/STELVIO Addition to front parking sensors in Proxy adjustment
Post by Gianmarco »
Dear,
I'm in the same situation, identical car and same update to ETM 2020.
I have also replaced climate control but rear sensor doesn't work, only front ones.
To be more precise after chanigng everything they worked till I went in Alfa for annual check. They have updated some unites (Body and ABS if I'm not wrong) and then they stopped working. I asked to go back to previous sw but technician sayd they cannot go back (I have already checked in other Alfa centers and seems it is true).
Have you solved or any other idea???
Gianmarco wrote: 23 Aug 2023, 14:33 Dear,
find out exactly what they updated. there was update for PDC which would disable them while in P. this update involved PDC, ABS and I think couple other modules. maybe dealer missed something during update.
Gianmarco
Post by Gianmarco »
Thx,
going to check with the dealer
DannGT
Post by DannGT »
GenTLe wrote: 14 Jan 2021, 15:48 After having installed the 8 channel module for the parking sensors (4 for the rear and 4 for the front bumper) in place of the 4 channel only (rear bumper only), and the sensors themselves, it would be nice to have the proxy adjustment entry to activate the front ones.
I've read (and someone, the guy that asked to MES support, tested it too) that changing the proxy bit 118 from 00 to 10 and doing the alignment would do the trick, making the front sensors to be visible on the infotainment display.
Still it would be great to have the entry voice into the MES without having to manually play with the bits, thing that can induce errors and so on.
Thanks, Alex
Which part no. of Parking 8 channel module you bought? And new or used? Also where in proxi can I find changing proxy bit 118 00 ?
Thank you
Daniel
DANIELE
Post by DANIELE »
you have to change the instrument panel to the my20 model because it has a different sw hw version
putting this version solves the problem with the sensors. 100% tested for both Giulia and Stelvio
Edwin_Liu
Post by Edwin_Liu »
I had one MY19 Giulia QV ,also add MY23 cluster ,ETM and climate control. Now I have the same problem, parking sensor would not working.
But when I disconnected the SGW wire and link 12+8 pass adapter, it works…
Also I have AFLS fault show on the cluster.
Thanks in advance.
bart
Post by bart »
Can somebody write the correct number for PDC module with support front parking sensors compatible with Giulia?
GenTLe
Post by GenTLe »
bart wrote: 12 Jun 2024, 12:48 Hello
For mine, which is the October 2017 version, it worked perfectly with the m.n. 50538367
bart
Post by bart »
GenTLe wrote: 27 Mar 2025, 22:18
Thank You for answer, i have the same and don't working :( I see you're proxi in post https://www.multiecuscan.net/forum/viewtopic.php?t=8375 and I have a big request: could you give me the part number and software version of the controllers in your car?
I need to find out why PAM doesn't want to work for me.
