Hi Chrener
No i don t have, i only put the wires of the Uconnect 5 to the 7.
What DAB aerial i have to buy?
Do you have DAB aerial?kzn14d wrote: ↑30 Mar 2022, 14:36 Hi to all.
I retrofitted an Uconnect 5 Live DAB in a Lancia Ypsilon 2012.
The proxy allignment executed well after a lot of adjustement but my mileage are still blinking.
Someone can help me with the correct proxy configuration?
My current proxy is 157 bytes
33 32 34 30 32 30 30 32 39 36 35 4F 55 54 50 55 54 2D 4A 49 54 20 11 11 21 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 03 80 73 06 E5 00 FF 00 A0 00 00 06 00 07 00 94 06 0D 01 3C 00 00 01 01 35 50 0A 5C 00 00 00 00 15 00 00 00 00 11 05 40 00 10 00 00 00 00 00 03 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B5 00 00 00 00 00 07 00 00 80 00 00 78 00 45 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
Thanks in advance.
Andrea
EDIT:
If no,
Load this proxi and run a proxialignment procedure.
33 32 34 30 32 30 30 32 39 36 35 4F 55 54 50 55 54 2D 4A 49 54 20 11 11 21 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 03 80 73 06 E5 00 FF 00 A0 00 00 06 00 07 00 94 06 0D 01 3C 00 00 01 01 35 50 0A 5C 00 00 00 00 15 00 00 00 00 11 05 40 00 10 00 00 00 00 00 03 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B5 00 00 00 00 00 07 00 00 80 00 00 78 00 41 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
I am sorry i answered to another member - my mistake...
To you: Can you share FES log from multiecuscan after profialignment procedure. It is in main MES directory...
I think that you have short proxi configuration...
try load this:
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01 00 00 00 00 00 00 70
And after proxi share newest FES Log file...
Same problem, same error B157A-13-DAB aerial.
Should i have to buy an aerial DAB antena to resolve the problem ?
Hi read in a topic for the Proxi Alignment to be
successful with your new UConnect 7 we
need 193 Hexidecimal places. I started out
by adding "00" until I reached 193
hexadecimal spots. You will then need to
change the following:
Byte 121= 40 Navi
Byte 121= 44 Navi+Audio
Byte 123= D5 Dab
Byte 130=01 Fiat logo
Byte 130= 05 Abarth logo
Byte 148= 05 Uconnect 7
Carplay, Android:
Byte 157=01 CarPlay
Byte 158=00
Byte 159= 00
Byte 160= 01 Android Auto
Nothing works
Byte 121= 40 Navi
Byte 123= D5 Dab
Carplay, Android:
Byte 157=01 CarPlay
Byte 158=00
Byte 159= 00
Nothing works
Hi everybody,
Someone can help me please, i m disappointed and don’t know What i can do.
I saw with the report MES, i have an [102A] errors Byte 148: 01 ->1D
Wish i help
Wish i help
Hi chreaner,chrener wrote: ↑01 Apr 2022, 17:03Do you have DAB aerial?kzn14d wrote: ↑30 Mar 2022, 14:36 Hi to all.
Thanks in advance.
Andrea
EDIT:
If no,
I have DAB earial and the earial error goes out when the aerial is plugged and the circuit il closed.
Please, can you explain what kind of changes have you done in the proposed custom proxy?
In any way thanks tou so much for your support,
Andrea
abarthmultijet
MitchL do you have a Uconnect 7 or 5?
Do you perform an allignment after you change the code?
Hi Abarthmultijet,
I had a Uconnect 5 and change for a 7 with NAV DAB w/o CarPlay.
