Fiat Freemont
Re: Fiat Freemont
Please add support for Fiat Freemont with Body computer Marelly (JF) with ECU ISO Code - BCM400B
If that code is already supported then please fix the possible bug explained here
viewtopic.php?f=3&t=5345
I've just activated the DRL with latest v3.7 so this post can be removed.
Re: Fiat Freemont
enable the tail lights when the drl is on
Re: Fiat Freemont
enable the rear lights when the drl is on.. now in Brazil is being requested.
also would create a drl profile to brazil
High beam with 7.8v
Rear lights on
in Auto position switch
Enabled when P and hand break are released.
High beam with 7.8v
Rear lights on
View first unread post
Are there any plans to add support for IOS Split View to get console? It would be very useful.
Re: Fiat Freemont
remote start
program keys
corning lights
Re: Fiat Freemont
nothing interest was done to freemont
-Program keys
-Lift all windows when locking the car
-Rear lights on when Drl is on
-Program keys
Re: Fiat Freemont
Capable to register keys / get the code / add keys /delete all keys
Configure the module to raise the windows when lock the car
Turn the back lights on when drl enabled
Re: Fiat Freemont
thanks for good support for our freemont
my list for future features is:
- automatic start&stop
- close the mirrors when lock the door
Re: Fiat Freemont
Hello! No more features available to Freemont?
Would program new FOBs.. use the skp900 scanner as reference
Cornering lights would be good if available in module
Re: Fiat Freemont - New REquests
Dears,
Try to find a way to add FOBs as the scanner SPK900
I guess this is the missing feature.
