What is this???
FESmobile - Windows Mobile version of Multiecuscan
Boris
Re: What is this???
Post by Boris »
yani wrote:
Boris wrote:I have made some more tests with several Win mobile devices.
General conclusion is that it works on devices where BT OBD can communicate with mobile device wihout serial port connection.
Then both FESmobile and dashboard work using direct BT connection.
On some devices when serial BT connection is disabled , FESmobile and dashboard don't work using direct BT connection (can't find it using Search for Bluetooth devices on both software). Dashboard doesn't work over serial port at all (FES works).
I think that serial connection on Dashboard needs fixing.
Ok, you are right. There was a problem with serial port connection to some interfaces. The one which I used for the initial testing was BT OBDLink and was working with no problems.
Anyway, I fixed the problem now and uploaded the fixed program. You can download it again.
Tried, don't work.
sussexa
Re: What is this???
Post by sussexa »
hi yani
tried to download the dashboard to windows 8 laptop already just updated to multiscan 2.1 ok no issues, but when I try to open downloaded dashboard file it just wont open, the file reads
fesdashboard_noinstall rar file 1100kb file
does this look right or wrong
many thanks darren
Re: What is this???
The RAR file is like a ZIP file. i.e. a compressed container.
Windows can not open RAR files itself. You need to download a program like 7-Zip from http://www.7-zip.org/
mrCharlessOils
Post by mrCharlessOils »
Out of pure curiosity, which model would that gizmo come in, like would that be an optional extra, a mod someones put in or is it something we all have?
Sent from my SGP611 using Tapatalk
BBOinsam
Post by BBOinsam »
Look at the attached picture, what is this, it was in some parts I received. Is it some kind of tool? About 3 inch diameter with 3 threaded holes.
Regards,
Clay
Luca
Re: What is this???
Post by Luca »
Boris wrote: 09 Apr 2014, 09:48 Don't work on Windows mobile device using ELM327 BT. Not able to connect, COM port is OK. The same device works perfectly with same COM port settings on FES Mobile 2.2.
I have tested Windows version on Alfa 147.
Works ok with ELM327 USB and BT, but using ELM327 BT refresh rate is slow. I am using the same COM port settings as on Multiecuscan.
Second screeen does not work OK, no data, maybe because I have disabled some of Trrip A-B settings on the Dashboard Menu.
I think that mobile version is more useful than Windows version.... hard to drive with laptop...
BTW how to activate and measure 0-20, 60, 100 ?
Ciao a tutti, sto provando Fes daschboard sulla mia 147 1.9 jtdm ma non riesco a collegarmi.
Utilizzo elm327 1.5 usb, lo stesso che uso da anni con MES.
Ho notato che velocità della porta 9600 pare inziare la connessione ma poi i pallini rossi in basso a sx vanno avanti all'infinito ma non si collega mai.
Translate By Mod.
Hello everyone, I'm trying Fes daschboard on my 147 1.9 jtdm but I can't connect.
I use elm327 1.5 usb, the same that I have been using for years with MES.
I noticed that port speed 9600 seems to start the connection but then the red dots in the lower left go on to infinity but never connect.
