activate cruise control on alfa mito 1.6 jtdm 120cv
mpaocetul
Re: activate cruise control on alfa mito 1.6 jtdm 120cv
Post by mpaocetul »
I have also installed original alfa radionav aftermarket on my mito band i have flashing odometer band some mycar disabled functions. Do you think that multiecuscan can do proxy allignement to solve the problem? Fiat examiner si notte abile to do allignement because of an error. Thanks a lot
mpaocetul wrote:Who can explain me the self-learning function of multiecuscan?
You have to be more specific... It is a general question...
If you mean self learning all parameters in engine ECU than in general it means you will reset parameters in engine ECU and you need to drive car for some time in all modes: slowly, fast, medium...
mpaocetul
Post by mpaocetul »
Thanks! It's what i mean! Can you answer me about the previous post?
Here is link: http://www.alfaowner.com/Forum/alfa-147 ... -cure.html
I test it myself and it works on most petrol cars. Does not work on diesel cars.
If you are doing it with diagnostic then follow instructions on the left yellow window - there you have instructions. ;)
