proxi alignment procedure
Re: proxi alignment procedure
If your small km clock on the left side of your dashboard is blinking continuously you can use PROXY for making it look normal - to be ON.
In general when some system is changed car, for example: CD/ radio or dashboard or mirror/ windows switch or cruise control or something else then you need to do proxy alignment so body ECU can recognize "new" system in the car.
Please keep in mind that all instrument clusters are not made the same for all Alfas 147 – that is different because there is different equipment in different cars...
haffonso
Post by haffonso »
so every change done.. i. e i will enable the drl in my freemont 15.. should i run proxy alignment once completed?
