Page 2 of 2
Re: Odometer 0,0 on multiple AR156 1.9 JTD 2002
Posted: 13 Aug 2013, 11:20
by ARomeo
ARomeo wrote:Me, too - 156 1.9 16V JTD M_Jet. With Alfadiag I started it but how- I cannot explane
I additional - my mileage shows 169 920, ECU - 4 530. What do you thing?
Posted: 13 Aug 2013, 11:23
by ARomeo
In additional - my mileage shows 169 920, ECU - 4 530. What do you thing? EDC16CF3 - 07.2003
Posted: 14 Aug 2013, 11:04
by alfa156sarajevo
s130 wrote:Well I will disagree.
I disputed your 100% claim that all cars ECU that show zero have been tampered with. May be true for some but not all so claiming 100% will uneccessarily frighten some people!
Fiat Croma EDC16/39 CF4 is a known case. (same ECU as AR159).
I have the above, from new and it has never been tampered with. Originally I could read an odometer value from the ECU many moons ago but then some FiatECUScan versions and time later the ECU mysteriously reported zero km and has done so ever since. Meanwhile the DPF odometer/distance etc. km counters in the ECU still work and for 'last replaced' shows a within tolerance value that matches the dashboard odometer. Explain that!
THIS IS A KNOWN ECU problem that others have also reported and has been discussed.
I agree with you 100%.
Posted: 14 Aug 2013, 11:43
by alfa156sarajevo
TribesMan wrote:If you see 0.0km then this is a sign of playing with odomter on the dashboard. 100%
Did change mileage in dashboard on few Italian cars and data in engine ecu still remained the same.
In dashboard is lower mileage but still everything works normally.
Mileages in dashboard and engine ecu are working separately - individually.
Posted: 13 Mar 2015, 21:08
by boch
same mine. 0 on the ECU odometer. i'm not sure about the history of my car so i can't say on a 100% that 0 on the odometer is only a bug in the software or hardware. parameter "Odometer at the last DPF replacement" shows similiar value as a dashboard - strange... another strage thing is a fact, that odometer start to work after disconnecting the battery for a few hours.
alfa156sarajevo wrote:TribesMan wrote:If you see 0.0km then this is a sign of playing with odomter on the dashboard. 100%
are you sure that you talk about ECU EDC16C39 CF4 (Multijet)? or cars where you change the milage on dashboard have EDC15C7 CF3? problem with milage=0 occurs (in most cases) with ECU EDC16C39 CF4 (Multijet)
Posted: 29 May 2015, 21:56
by alfa156sarajevo
If you have EDC16C39 CF4 ECU and problem with 0 km in Odometer field, that means you probably need to do ECU update by official Fiat/ Alfa dealer...
Posted: 30 May 2015, 11:15
by boch
Thanks for response. But any details? What you mean update ECU? Can You tell me what is the latest version of software to EDC16C39 CF4?
Posted: 31 May 2015, 15:45
by alfa156sarajevo
boch wrote:Thanks for response. But any details? What you mean update ECU? Can You tell me what is the latest version of software to EDC16C39 CF4?
I do not know which is latest version of software for EDC16C39 CF4!
Some people with Alfa 159 had the same problems and solution was "update by official FIAT dealer"!
Later they had possibility to read original km with MES!
Posted: 04 Jun 2015, 20:26
by boch
alfa156sarajevo wrote:Some people with Alfa 159 had the same problems and solution was "update by official FIAT dealer"!
Great news. I'll try to contact with the local Fiat dealer. Thanks!
