Re: Execution Problem
Posted: 05 May 2014, 21:38
Same problem here with Windows CE 6.0 and FESmobile 2.2 on a 320x240 display. I can test if you want to fix it.lancialybra wrote:Yani, I hided the task bar and there is little improovement (appears about 95% the second line) but no third line.
But, if you scroll down to the end and click once time to the up, appearing the third line. If you click a more that once, again the third line is dissappearing! This is very strange!
The win CE 5.0 doesn't any rotate the screen at Settings/Control Panel/Display. The resolution is fixed.
