Option to change km
stefano
Re: Option to change km
Post by stefano »
I say it is useless option just so you can add km,
for example when I made the program multiecuscan looks less with 176 km than indicated in the board machine, in this case what should I do?
to add or delete km?
-multiecuscan just to give me the opportunity to add...... :D
So I want to be this option that we can and remove km in case it is needed. :(
Fiat per sempre..... mai piu.
I understand you quite well.
I too have differing mileages between the engine ECU and instrument odometer as do others.
In most garages, especially ofical dealers, if you need a replacement instrument cluster then this will be supplied with less than 10km on the odometer. When fitted, proxi aligned and setup it will be set to the shadow value from the body computer.
Yes us DIY people will go to a scap yard and get a second hand unit and want to fit that and wind the mileage back.
This does not change the fact that but 'normal' means the odometer values can only be increased via the offical and documented procedures. Anything else is a 'hack' and if I were to write such software I would never sell it for all sorts of reasons, least alone potential legal ones.
A long while ago (somewhere here in this forum) Yani did say he would not do this function even if he could, so he has already responded with a NO.
I agree with you s130!
Cheers ;)
stefano
Post by stefano »
alfa156sarajevo wrote:I agree with you s130!
Cheers ;)
s130 ??? alfa156sarajevo why is this
Maybe alfa156sarajevo is just posting his/her view as well.
I don't personally know the guy/girl but they are entitled to their view.
orso yoghi
Post by orso yoghi »
Stefano cmq esistono altri software e hardware da spendere circa una cinquantina di euro che compiono questo lavoro ma soltanto sul quadro se li vuoi modificare nella ecu allora ci volgiono cose più sofisticate ciao....dalla Sardinya!!
for those who want or need to change the km has purchased a used equipment because there are other hardware and software that perform this function memmeno very expensive.
Cheers ;)
stefano
No hard feelings, please... ;)
I am just thinking that purpose of this software is to perform various diagnostics tasks on Fiat, Alfa and Lancia vehicles...
On the internet you can find many people, like Yani, who are developing software for dashboard calibration (change km)...
You will find that license for that kind of programs are not cheap... At least 200€... + yearly updates... :shock:
stefano
Post by stefano »
I agree to pay even more just to be and this option included.
tzok
Post by tzok »
stefano wrote:I agree to pay even more just to be and this option included.
So go and buy "FIAT KM TOOL" (Fiat CAN v1.0) it costs ~100€ together with a dedicated interface and works over OBD connector. This program is made solely for this purpose.
FIAT ECU Scan is made to be a diagnostic tool and let it be just a diagnostic tool.
This topic is now Locked by moderator.
Multiecuscan can only increase the Odometer value. It only supports and adheres to official manufacturer's interface commands.
There are other products available that can alter odometer values both up and down via unofficial methods/hacks.
If you require a product to decrease your odometer value then Multiecuscan is NOT a product you should be looking at and you should should look elsewhere.
Locked
